Seldur
Flottur skjár í toppstandi fyrir 1080p spilun. 144hz og 1ms gerir skjáinn mjög góðan í alla leikjaspilun fyrir meðaltölvur og upp.
Verð 23þ. eða tilboð.
https://www.displaydb.com/monitor/aoc-g2770pf
https://www.tomshardware.com/reviews/ao ... ,4472.html
Despite the cons we've noted, there really isn't anything to dislike about the G2770PF. It's well-built and presents a clear image with high contrast and plenty of available brightness. FreeSync works over a wide 30-144Hz range setting it apart from several more-expensive monitors. At a price well under $400, it seems like a great choice for gamers on a budget.
Specification:
- AMD FREESYNC Technology
- Monitor Size: 27"
- Visible Screen Size: 68.58 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Viewing Angle: 178°/170° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Scanning frequency: H: 30-83 KHz (30-160 KHz DVI-D) / V: 50-76 Hz (50-146 Hz DVI-D)
- Recommend Resolution: 1920 x 1080@144 Hz (DP/DVI-D)
- Colors: 16.7 M
- HDCP compatible: yes
- Height adjust, pivot & swivel
- Inputs: DisplayPort, DVI-D, HDMI & Analogue
- Warranty: 3yr
