[TS] Audio-Technica Condenser microphone AT2022
Höfundur - Nörd
- Póstar: 125
- Skráði sig: Mið 30. Apr 2014 10:02
Er með nánast ónotaðann AT2022 sem var keyptur fyrir nokkru síðan í Origo. Konan mín ætlaði að nota hann í hljóðupptökur fyrir Video sem hún var að gera á þessum tíma, en datt svo út úr því og micinn því aldrei notaður nema til þess eins að prufa hann.
Hann kemur í upprunalegum kassa með öllu sem honum fylgdi.
Verðhugmynd 20.000 kr
Vörulýsing
AT2022
IDEAL MICROPHONE FOR STEREO QUALITY RECORDINGS
Designed specifically for stereo field recording, interviews and home
recording, the compact and lightweight AT2022 is suitable as a handheld
microphone as well as when mounted on a boom or camera. Ideal for
recording reports, the AT2022 unidirectional condenser capsules provide
you professional quality stereo, without the need for 48V phantom power.
Its 1.5V AA battery enables you to connect to virtually any audio
recorders. The capsules can be rotated 90 or 120 degrees, to control the
stereo width of your recording, and fold completely for easy storage and
transportation.
X/Y stereo microphone with unique pivoting electret condenser capsules
for ultimate flexibility
User-selectable 90° or 120° stereo operation for narrow or wide pickup
patterns
Provides the spatial impact and realism of a live sound field
Battery operation allows use with most recording devices
Switchable low-frequency roll-off minimizes pickup of unwanted low-
frequency noise
Ideal for general stereo recording and field sound capture
Excellent channel separation
Works with a standard 1.5V AA battery (included)
Included fuzzy windscreen offers excellent wind protection
Tækniupplýsingar
Element Fixed-charge back plate, permanently polarized condenser
Polar Pattern X/Y Stereo
Frequency Response 20 - 20,000 Hz
Open Circuit Sensitivity -41 dB (8.9 mV) re 1V at 1 Pa
Impedance 200 ohms
Maximum Input Sound Level 122 dB SPL, 1 kHz at 1% T.H.D.
Channel Balance 2.5 dB
Low Frequency Roll Off 150 Hz, 6 dB/octave
Switches Off, on/flat, on/roll-off
Dynamic Range 103 dB, 1 kHz at Max SPL
Signal-to-Noise Ratio 75 dB, 1 kHz at 1 Pa
Battery Type 1.5V AA/UM3
Battery Current/Life 1.2 mA / 500 hours typical (alkaline)
Weight 270g
Dimensions 192.0 mm (7.56") long,
65.0 mm (2.56") maximum head diameter,
21.0 mm (0.83") body diameter
Output Connector Integral 3-pin XLRM-type
Cable 0.5 m (1.6') long, 3 conductor, shielded, vinyl-jacketed stereo
cable with 3-pin XLRF-type connector at microphone end and 3.5 mm (1/8")
TRS connector at output end
Accessories Included AT8405a stand clamp for 5/8"-27 threaded stands;
fuzzy windscreen; battery; soft protective pouch
The AT2022 is a condenser microphone designed for stereo recording. Two
unidirectional condenser capsules in an X/Y configuration pivot to allow
for narrow (90°) or wide (120°) stereo operation. The capsules also fold
flat for storage and transportation. Designed for general stereo
recording and field sound capture, the AT2022 provides the spatial
impact and realism of a live sound field. The microphone comes equipped
with a stand clamp, AA battery, fuzzy windscreen and .5 m cable that
terminates in a 3.5 mm stereo plug.
Vörulýsing
AT2022
transportation.
patterns
frequency noise
Tækniupplýsingar
Impedance 200 ohms
Weight 270g
Höfundur - Nörd
- Póstar: 125
Re: [TS] Audio-Technica Condenser microphone AT2022
Skoða öll tilboð
