selt selt selt: Benq 240hz G-Sync / Freesync skjár
Sallarólegur
Póstar: 6350
Staðsetning: https://viktor.ms
Póstur af Sallarólegur »
Fast verð 55k
Í toppstandi - Hef ekki tíma fyrir leiki næstu misserin.
Kostar 90k nýr
Sami skjár og allir pro CS spilarar nota á stóru mótunum!
http://zowie.benq.com/en/product/monitor/xl/xl2540.html
Display
LCD size (inch)‎
24.5
Aspect ratio‎
16 : 9
Max. resolution
1920 x 1080 at 240Hz (HDMI 2.0, DP)‎‎
Display area
543.744 x 302.616‎
Pixel pitch (mm)
0.28
Typ. brightness (cd/㎡)‎
400
Typ. contrast ‎
1000 : 1
Typ. DCR (DyNamic Contrast Ratio) ‎
12M : 1
Panel type‎
TN
Response time‎
1ms (GtG)
Connectivity‎
Input/Output connector‎
DVI- DL / HDMI x2 / DP1.2 / headphone jack / microphone jack‎‎‎
USB‎
Downstream x3 Upstream x1‎‎‎
Electricity‎
Power supply (90~264 AC)
Built- in‎‎‎
Power consumption (On mode)‎
55W
Size & Weight‎
Dimensions (HxWxD mm)‎
High: 515.43 x 569.94 x 226.04 Low: 445.75 x 569.94 x 226.04‎
Net weight (kg)‎
7.5
Gross weight (kg)
11.3
Stand‎
VESA wall mounting 100x100 mm‎
V
Pivot 90°‎
V
Swivel (left/right)‎
45/45
Tilt (°)‎
-5 ~ 20
Height adjustment (mm)‎
140
Special Features‎
Shield‎
V
S Switch‎
V (Profiles to go)
Black eQualizer
V
Color Vibrance‎
V
Low Blue Light‎
V
Flicker-free
V
K Locker‎
V
Variable Refresh Rate Technology compatible
V (G-SYNC compatible , FREESYNC)
kristjanfinns
Póstar: 6
Skráði sig: Sun 16. Jún 2019 21:49
Re: TS: Benq 240hz G-Sync / Freesync skjár
Póstur af kristjanfinns »
eg er til i ad taka hann, sendi ther skilabod.
