Vel farinn eins og hálfs árs gaming skjár til sölu, kostar 30þús í retail en ég skoða tilboð
Display
LCD size (inch)
24
Aspect ratio
16:9
Max. resolution
1920 x 1080 at 144Hz (DVI-DL)
Max. resolution
531.36 x 298.89
Pixel pitch (mm)
0.276
Typ. brightness (cd/㎡)
350
Typ. contrast
1000:1
Typ. DCR (DyNamic Contrast Ratio)
12M:1
Panel type
TN
Response time
1ms (GtG)
Connectivity
Input/Output connector
D-sub + DVI-DL + HDMIx1 / headphone jack
Electricity
Power supply (90~264 AC)
Built-in
Power consumption (On mode)
45W
Size & Weight
Dimensions (HxWxD mm)
431 x 570 x 222
Dimensions with wall mount (HxWxD mm) (w/o Base)
347 x 570 x 63
Net weight (kg)
5.9
Gross weight (kg)
8.4
Stand
VESA wall mounting 100x100 mm
V
Pivot 90°
V
Swivel (left/right)
45/45
Tilt (°)
-5~20
Height adjustment (mm)
130
Special Features
Black eQualizer
V
Low Blue Light
V
Flicker-free
V
K Locker
V
BenQ XL24LL 24'' 1920x1080 144hz
fannarbannar
Höfundur - Nýliði
- Póstar: 2
- Skráði sig: Mið 17. Apr 2019 13:36
fannarbannar
Höfundur - Nýliði
- Póstar: 2
Re: BenQ XL24LL 24'' 1920x1080 144hz
15.000kr sótt, aðeins í kvöld! sími 7718280
Sæll. Tek hann. S:8987013.
