Introduction
As insurance cost keeps climbing up, if the HD video proof could work for you just once, you could save more money than the price of this dash cam.
The R100 Dash Cam has a number of modern solutions, useful for all drivers. The dashcam starts recording immediately after turning on the ignition. It has a night mode ensuring high quality recordings also in poor lighting conditions. The WDR system will make no detail escapes high quality R100 dash camera lenses.
The R100 Dash Cam records Full HD videos in 1296P at 30 fps with H.264, and full HD (1920*1080P) from rear camera! The use of six-glass lenses and an extremely sensitive sensor ensure excellent quality. As a result, the video quality is very detailed and smooth.
Advanced Parking Mode
* Unique AUTO-OFF feature: Useful for some cars that always supply power to its cigarette lighter port, you do not have to manually turn off your R100 Dash Cam each time you turn your car off.
* When the R100 detects any movement, it will start recording for a short period of time (Require constant power supplied).
Why To Choose R100
* 2 lens system can well cover both front (140°) and rear (140°) in super wide angle
* Rear Camera can record 1080P HD quality video, not normal VGA low resolution or 720P.
* Premium real HD quality video 1296P + 1080P for day and night use
* Super Large 800mah battery can last longer without power input
* High quality IPS screen is much better than others normal TN screen
* Support 64/128GB card (most other models can only support up to 32GB card)
* Quick-response support team provides worry-free solutions
* We care about our customers!
Safety First
This dash cam connects directly to the back-up light so that every time you reverse it senses that and automatically starts displaying footage from the rear camera on the screen.
Emergency Lock Button & Accident Auto Detection Feature (G-Sensor) can lock current video file for you.
High Quality Li-polymer 800mah battery can bear high/low temperature, with official MSDS report and the most strict PONY Lab Certificate
Kostar nýtt 27 þús og hefur ekkert verið notað, hef bara prófað tækið og er vika síðan ég fékk það í hendurnar.
Verð: 20 þús
Fleiri myndir: kdlinks.com
