Skjárinn var keyptur í lok árs 2015 í Tölvutek og er mjög vel með farinn - sér ekki á honum.
Get látið HDMI og/eða DVI kapla fylgja.
Nánar um skjáinn:
Display
Aspect Ratio: 16:9
Resolution (max.): 1920 x 1080
Display Area(mm): 621 x 341
Pixel Pitch (mm): 0.320
Brightness ( typ.): 300 cd/㎡
Native Contrast ( typ. ): 3000:1
DCR (Dynamic Contrast Ratio) (typ.): 20M:1
Panel Type: VA
Viewing Angle (L/R;U/D) (CR>=10): 178°/178°
Response Time(Tr+Tf) typ.: 5ms (GTG)
Display Colors: 16.7 Million
Color Gamut: 72% NTSC
Back Light Unit: LED
LCD Size: 28
Input/Output
Input/Output Connector: D-sub / HDMI x 2
Signal Cable: VGA / HDMI
Headphone Jack: Yes
Dimensions & Weight
Dimensions(HxWxD mm): 477 x 659 x 204
Dimensions with Wall Mount (HxWxD mm): 381 x 659 x 54
Net Weight (kg): 5.5
Special Features
Flicker-free Technology: Yes
Low Blue Light: Yes
AMA: Yes
HDCP: Yes
Color Temperature: Reddish / Normal / Bluish / User Mode
OSD Language: 17 Languages
VESA Wall Mounting: 100 x 100
Tilt (down/up): -5° / 15°
Dynamic Power Saving (DPS): Yes
K Locker: Yes
Tilboð óskast - verðlöggur velkomnar !
