Var að vellta fyrir mér hvað maður getur búist við að fá fyrir rúmlega 1 og 1/2 árs gamalt Asus Strix R9-390? fer að detta í að vera 2 ára gamallt.
Upprunalegar pakkningar gætu ekki fylgt með ef það breytir einhverju með verðið og ábyrgðin fer að renna út... Einhverjar hugmyndir?
Verð fyrir notað strix R9-390?
|-Evolv X-|-Asus Z370 Gaming-|-i7 8700k-|-Noctua NH D15-|-2x8GB Vengeance 3200MHz-|-SuperNova 750 B2-|-Asus GTX 1080 Strix-|
Re: Verð fyrir notað strix R9-390?
fann þetta a netinu.
970 kortin eru að fara á 17 til 20þ kr.
It'll depend on your priorities, the two are too close in terms of performance to separate that way so you need to think about what is most important to YOU.
Apart from lower power consumption the GTX970 will be a little quieter and pump a lot less heat into the case, so if you're after a quiet system it's the card to go for.
Also Nvidia have a few software tricks you might consider: PhysX boosts cloth/water/smoke/particle realism-although not every game supports it-and they have several anti aliasing modes that give good results with a lower frame rate hit than AMD users can enjoy. If you want to record gameplay for video (youtube etc) Shadowplay has a lower performance hit than the AMD Raptr streaming/recording software.
With that huge 8Gb of memory the R9 390 is going to handle heavily modded games more easily than the GTX970 so if you're a graphics junkie and have to have the latest high res texture packs and realistic vegetation addons and can accept the requirement of more/stronger/nosier case fans the R9 390 is the card you need.
I'll draw on old experience here and say that the larger memory will also, probably, help smooth out the gameplay a little by eliminating or reducing those tiny glitches you get when making sharp turns or moving from inside to outside scenes that force the card to stream extra texture data from HDD or main memory.
GPU: Asus Turbo 2080 ti - GA z590 gaming X - Intel Core i7 11700k - Corsair Rm750x - Noctua-U12S - iCUE 465X RGB Mid-Tower- AORUS RGB Memory DDR4 16GB x4 3733MHz - Samsung 970 EVO 1TB M.2 2280 SSD - Win 10 Pro 64bit - ASUS ROG Swift Curved PG348Q @ 100mhz
Glæsilegt, takk fyrir þettaAimar skrifaði:fann þetta a netinu.
Kannski að maður setji 25þ á þetta og sjái hvað gerist, þessi 8gb hljóta að vera að skila sér...
