[Seldur] be quiet! Dark Base 900 Pro - Black Turnkassi [Einn Sá flottasti]
jojoharalds
Höfundur - Bara að hanga
- Póstar: 1591
- Skráði sig: Þri 02. Nóv 2010 20:42
- Staðsetning: Cicada - 3301
Góðan dag,
Er me til sölu mjög flottan turnkassa frá be quiet!
Dark Base 900 pro All black - með þráðlausri símahleðslu innbyggð.
Þetta er án efa einn sá flottasti á markaðnum í dag og án efa einn með þeim mestu breytinggum í huga
Removable Motherboardtray,
ekkert mal að breyta hæð á móðurborðinu,
möguleiki að breyta í inverted motherboard mount,
nóg af pláss fyrir Harðadiska,
LED strípur fylgja
og svo má ekki gleyma hert gler með smá tínt.
þessi kassi hefur fengið fjölda verðlauna,
Hér er listi með speccunum
be quiet! Dark Base Pro 900: unrivaled flexibility with impeccable cooling and silence features. It was designed for high-end enthusiasts and individualists – all of those who expect the highest standards when it comes to modularity, compatibility and design for their high-end workstations as well as overclocked and silent water-cooled systems.
Dark Base Pro 900 has numerous modularity options to satisfy every desire with lots of features to support special configurations. Aluminum surfaces and steel offer highest stability with a look of extreme elegance. Simply an engineering work of art!
Fully versatile thanks to modular construction, offering an relocatable motherboard tray, repositionable HDD slots, support for even E-ATX and XL-ATX as well as the possibility of an inverse layout
Three pre-installed SilentWings® 3 140mm PWM fans featuring a smooth-running 6-pole motor, fluid-dynamic bearing and funnel-shaped air inlets
Effective full circuit airflow system with innovative noise-reducing vents all around the case
Completely sound insulated case with decoupled elements for motherboard, power supply and drives
Four areas for water cooling radiators up to 420mm on top, front, back and base of the case
Elegant, fully windowed side panel made of tinted and tempered glass
Eye-catching LED illumination with five switchable colors that you can freely position in the case
Integrated wireless charger for Qi enabled devices such as smart phones
PSU form factorATX PS/2
Motherboard compatibilityE-ATX, XL-ATX, ATX, M-ATX, Mini-ITX
Installation of motherboards with backplate✓
Case size excl. stands (L x W x H), (mm)-
Case size incl. stands (L x W x H), (mm)577 x 243 x 585
Dimensions side panel window (L x W), (mm)479 x 525
Color optionBlack
Weight (kg)14.39
USB 2.02
USB 3.02
HD Audio I/O1
Expansion slots8
Fan mounting locations10
Top CoverABS, Aluminium
Side panelSteel, ABS
Side panel window4mm Tempered Glass
Front panelABS, Aluminium
StandsABS
Drivebays
5.2 -52
3.5 -7
2.5 -15
Removable Dust filter
Allt fylgir með honum og er kassin eins og nýr.
Verð 30.000 kr
LED strípur fylgja
Color optionBlack
Weight (kg)14.39
USB 2.02
USB 3.02
HD Audio I/O1
Expansion slots8
StandsABS
Drivebays
5.2 -52
3.5 -7
2.5 -15
Verð 30.000 kr
- A68V_131105380007043051n9709ipuWC.jpg (26.21 KiB) Skoðað 1087 sinnum
- A68V_131105380079386484HU16xeT3j4.jpg (32.11 KiB) Skoðað 1087 sinnum
- A68V_131105380132041526yMTa62yBUw.jpg (26.35 KiB) Skoðað 1087 sinnum
- A68V_1311053799829808064YmQiE0JvJ.jpg (18.23 KiB) Skoðað 1087 sinnum
- A68V_1311053800120429483Uyq8BLnuF.jpg (31.39 KiB) Skoðað 1087 sinnum
- A68V_1311053800275115278fRbi5bVbh.jpg (28.72 KiB) Skoðað 1087 sinnum
jojoharalds
- Póstar: 1591
Re: [Til Sölu] be quiet! Dark Base 900 Pro - Black Turnkassi [Einn Sá flottasti]
jojoharalds
- Póstar: 1591
Þú átt PM, um að gera að svara mér þar
jojoharalds
- Póstar: 1591
jojoharalds
- Póstar: 1591
jojoharalds
- Póstar: 1591
jojoharalds
- Póstar: 1591
