Ég er að spá í að kaupa auka minni, er með x4 2gb ddr3, vill kaupa annað hvort x4 4gb eða x2 8gb.
Vantar ráð hvaða typu ég á að kaupa hvað hraða, er búinn að skoða þetta á att.is
http://att.is/products/vinnsluminni-bordtolvur-ddr3
Fann þetta :
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to http://www.asus.com or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Móðurborð .
Manufacturer ASUSTeK COMPUTER INC.
Model MAXIMUS V GENE (LGA1155)
Version Rev 1.xx
Chipset Vendor Intel
Chipset Model Ivy Bridge
Chipset Revision 09
Southbridge Vendor Intel
Southbridge Model Z77
Southbridge Revision 04
Örgjafi :
Intel Core i7 3770K
Cores 4
Threads 8
Name Intel Core i7 3770K
Code Name Ivy Bridge
Package Socket 1155 LGA
Technology 22nm
Specification Intel Core i7-3770K CPU @ 3.50GHz
Graphics
Monitor
Name Acer XB281HK on NVIDIA GeForce GTX 1080
Current Resolution 2560x1440 pixels
Work Resolution 2560x1403 pixels
State Enabled, Primary
Monitor Width 3840
Monitor Height 2160
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Manufacturer NVIDIA
Model GeForce GTX 1080
Device ID 10DE-1B80
Revision A2
Subvendor Gigabyte (1458)
Current Performance Level Level 1
Current GPU Clock 696 MHz
Current Memory Clock 405 MHz
Current Shader Clock 405 MHz
Voltage 32.760 V
Bus Interface PCI Express x16
Temperature 37 °C
Driver version 21.21.13.7849
BIOS Version 86.04.17.40.38
Memory 4095 MB
Kaup á minni
Höfundur - Nýliði
- Póstar: 1
- Skráði sig: Þri 14. Feb 2017 18:54
