[Buildlog] Project Cyber K.I.D
jojoharalds
Póstar: 1591
Staðsetning: Cicada - 3301
Póstur af jojoharalds »
Sælir ,
Datt í hug ég deili með ýkkur (þau sem hafa áhuga) ferlið af Fractal Design Define C Verkefninu mínu,
Project Cyber K.I.D.
Njótið myndirnar.
Part 1:
So tha plans are as followed,
Removing the rear panel of the Fractal Define C Case and Building my own out of 3mm rustfree steel.
i had laying around a piece that almost fitted perfectly (i thought only shortening it would do)
but i had to drimm off the side a litte - 4mm to be exact.
then i had to file everyting to fit nicely,especially the corners they had to be a exact to fit nicely in the bottom and top panel.
after that i had to preinstall the mainboard and draw where the IO cutout had to go,from there the next step where to think about how i wanted to have the GPU,since the main reason for reconstructing my own backpanel was the polacement of the gpu in a differrent way.
after that it was simple,take the jigsaw with an ireon blade and cut out the two holes file everything down and make it look a little cleaner,
then go over everything with some sandpaper to make it "babybuttsmooth" :)
After everything was ready ,it was off to paint,first primer and then black matt paint to match the paint of the case (at least try).
let everything dry for 48 hours or so,the assemble everything.
next i painted the mainboard cover of the Asus Sabertooth Z77 Motherboard which will house a delidded 3770k which should be plenty
for gaming the next few years overclocked @ 4.6- 4.8 ghz.
and don´t worry the motherboard cover will not be so green in the end (these are only the first steps)
Stay tuned for more to come soon :)
installed the waterblock on the 970 card
and
did finetune the cosmetic aspects of the gpu a little with some custom vinyl and some acrylic :-)MyndMyndMyndMynd
working on Cables and led's today.
Have to train the cables forst though.
*tightfit.
Also speedmatching the two pumps.
one is an Alphacool D5 and the other is a
alohacool Dc LT.
MyndMyndMynd
Almost there...
Myndalmost there.....
jojoharalds
Póstar: 1591
Re: [Buildlog] Project Cyber K.I.D
Hey everyone i would like to share with you the final outcome of my just finished work on the Fractal Design ´s Define C Computer Case.
Hope you like the final pictures.
Thank you for checking out my Buildlog.
Until soon!!!
MyndMyndMynd
MyndMyndMyndMyndMyndMyndMyndMyndMyndMyndMyndMyndMyndMyndMyndMyndMynd
gotit23
Póstar: 606
Póstur af gotit23 »
Holy Moly,Þetta er svakalega vel gert!!!
Hlakka til að sjá hvaða smiði koma næst frá þér,
Dúlli
Póstar: 2097
Póstur af Dúlli »
Ok, þetta mod er einum of flott hjá þér vel gert.
Hvað ertu eiginlega komin með marga kassa hjá þér ? orðin frekar virkur undan farnar vikur :happy
jojoharalds
Póstar: 1591
Dúlli skrifaði:Ok, þetta mod er einum of flott hjá þér vel gert.
Takk fyrir hrósið :)
eins og er er ég með 7 kassar hjá mér,
2 af þeim eru í vinnslu hítt er í bið eftir hugmydnum (er að teikna níður og púnkta niður hvað þarf að gera hugmyndum og annað)
einn af þeim 7 er Powermac G5 Sem ég er mjög spenntur í að vinna með !!
jojoharalds
Póstar: 1591
gotit23 skrifaði:Holy Moly,Þetta er svakalega vel gert!!!
Takk fyrir hrósið ,margt planað sumt í vinnslu :)
keep u posted!!
mundivalur
Póstar: 2324
Staðsetning: South side
Póstur af mundivalur »
Flott build :happy en engar UV myndir :D áttu ekki UV led frá mér ?
jojoharalds
Póstar: 1591
mundivalur skrifaði:Flott build :happy en engar UV myndir :D áttu ekki UV led frá mér ?
Takk fyrir :) Jú er með aurora Led í kassanum :)
jojoharalds
Póstar: 1591
Hér eru nokkrar LED myndir :)
möguleiki að nálgast þessu led kerfi með mísmunandi stillingum og á góðu verði,
á Icemmodz.com
http://www.icemodz.eu/#!/Lighting/c/534 ... ort=normal
gotit23
Póstar: 606
Póstur af gotit23 »
Töff, hvernig græni líturinn fær UV effect með Led ljósinu!!
jojoharalds
Póstar: 1591
Hér stutt myndband af projectinu.
https://www.youtube.com/watch?v=dG1DFE3Wd_U
gotit23
Póstar: 606
Póstur af gotit23 »
Þetta er hríkalega flott ,mjög vél gert !!
jojoharalds
Póstar: 1591
gotit23 skrifaði:Þetta er hríkalega flott ,mjög vél gert !!
Takk fyrir :)
