AGP 3.0Volt kort virka ekki í nýjum p4 móbóum?
Höfundur - Nýliði
- Póstar: 16
- Skráði sig: Mán 05. Maí 2003 16:10
Mun Geforce256 3.0Volt skjákort ekki virka í nýjum P4 móbóum? Eru þau bara gerð fyrir 1.5Volta kort?
Einhver sem er snillingur í þessu volta braski á AGP....
Annað: Hvernig kort á maður að fá sér í dag? Er ekki alltaf í leikjum, en vill fá kort sem virkar án vandamála í tölvuleikjum. Má kosta 20~30þús
- Alveg Anton
- Nýliði
- Póstar: 11
- Skráði sig: Mán 17. Mar 2003 19:54
"The Pentium 4 Chipsets i850 & i845 only support 1.5 volt 4x AGP.
Older chipsets (e.g. VIA 693 and Intel BX) support 3.3 volts AGP 2x, however newer chipsets are downward compatible to 2x/4x (e.g. 815EP, 815EP B stepping and VIA 694X) and support 3.3 volts as well as 1.5 volts.
This does not apply to the Pentium 4 chipsets because the i850 und i845 only support 1.5 volts graphic boards (regardless of 2x or 4x). Therefore the 3.3 volts 2x VGA graphic boards cannot be installed in a Pentium 4 system any longer.
The graphic board as well as the motherboard will be destroyed after installing a 3.3 volt graphic board. EPoX grants no guarantee in these cases of user's own faults. You find a corresponding hint to the 1.5 volts graphic boards on the pages 1-5 of the P4 user's manuals
http://www.hardtecs4u.com/reviews/2001/agp4x_e/
Current popular chipsets like Intel i815, VIA KT133(A), KT266(A), AMD 760(MP) etc. are supporting both AGP working voltages of 1.5 and 3.3V, whereas motherboards based on Intel's i845 or i850 chipset and nVIDIA's forthcoming nForce are unable to work with 3.3V graphic boards, absolutely requiring an 1.5V AGP graphic board for avoiding damage of both mother- and graphic board
http://www.hardtecs4u.com/reviews/2001/agp4x_update_e/
Mér sýnist allt benda til þess að flest p4 móðurborð 8X séu með 1.5 volt AGP og sennilegast þá ættu 3.3volta skjákort ekki að passa í 1.5volt AGP slot, gæti verið að hægt sé að finna 4xAGP móðurborð(x1/x2/x4) sem ráði við bæði 1.5 og 3.3 volt kort
KiddiZip
Höfundur - Nýliði
- Póstar: 16
Já, Kiddi kidi kiddi...
Já, er að planleggja framtíðina, og NEII, ég er ekki að fara að missa kortið mitt, var að kaupa nýtt kæliunit á það... og overclocka. Get meira að segja keyrt Generals í *hóst* fínum gæðum án þess að það frjósi allt... Hitinn er samt um 75-80° á greið kortinu :/ en það er bara cool (eða ekki cool...kannski)
- Alveg Anton
- Nýliði
- Póstar: 11
hmm, já nýtt kælikerfi...ég setti reyndar gamla viftu sem var á pentum 200mhz á kortið mitt (riva tnt2 ultra) og vó miklu hljóðlátari tölva eftir það, þurfti reyndar að saga kæliplötuna aðeins til en virkar fínt...á eftir að prófa að overclocka En ef þú ert að pæla í að uppfæra þá mæli ég með móðurborð's með intel 875 kubbasettunum fyrir 400/533/800 FSB örgjörva, kaup sér celeron 2,4 og síðan bíða eftir að stóru 800fsb örrarnir lækki í verði!!! og já ti4200 x8 er held ég bestu kaupin í nvidia (sem við höfum að sjálfsögðu svo góða reynslu af)
KiddiZip
Höfundur - Nýliði
- Póstar: 16
Já
Já, en mér langar ekki í Celeron !!! punktur !!!
Spurning með að kaupa sér nýja ASUS móbóið (Intel kubbasettið), nýjan skjákortus, gíg-minni... og svo 2GHz~2,4GHz.... einhverntíman eftir fjóra dempara eða svo
- Alveg Anton
- Nýliði
- Póstar: 11
Sammála með það ég mundi ekki fá mér celeron á meðan ég hefði efni á að kaupa mér eitthvað betra, en já það þýðir ekkert annað en asus móðurborð! Engin bitur reynsla það, ertu að pæla í að fara í p4 í sumar einhverntíman? Ég er að drepast mig langar svo að kaupa mér tölvudót! En fyrst skjákort!!! (og hdd).
KiddiZip
Höfundur - Nýliði
- Póstar: 16
Kaupa & staup
Já ég er að spá í að kaupa svona í sumar
Ég ætla að vera sá svalasti hehehe
- Alveg Anton
Höfundur - Nýliði
- Póstar: 16
Svona kannski
CPU, Intel, Socket 478, 2.4GHz
ASUS P4C800 DL Raid, Pentium 4, 533/400 MHz FSB, AGP Pro 8x, 5 PCI raufar, DDR, 4 SATA tengi, 8 USB, með innbyggðu hljóðkorti og 3COM Gigabit LAN ásamt 1394 Firewire
2 x RAM, DDRAM 184 pinna, 512MB
VGA, ASUS V9280, AGP 8x, 128MB DDR
Samtals krónur: 90.000++ <----
Það er spurning hvort að maður eigi ekki að skella sér á þetta, en bíða samt aðeins eftir meiri lækkun
Þetta ætti að geta opnað word skjöl!
Annars er fínt hjá okkur að fara að plugga þessu inn hjá stúlkunum, svona láta þær finna fyrir þvi að við þurfum að fara að upgreita... þjarma að þeim og væla... hehehehe.... segjast ekki geta komið strax uppí rúmm, því tölvan er svo lengi... o.s.frv.
- Alveg Anton
