Vandamál með að tengja inn ps4 við sjónvarp
jardel
ÜberAdmin
Póstar: 1307
Póstur af jardel »
Er að tengja nýja ps4 vél við plasma tæki hdmi hdmi
þetta gekk vel fyrst en leið og ég var búinn að fara í gegnum styllingarnar fékk ég svartan skjá er búinn að prufa að googla um þetta án árangurs.
Búinn að prófa nánast allt líka það sem þessi hér fyrrir neðan gerði.
I'm suffering just the same. I can't see anything via hdmi, take a look what I've just posted 2 minutes ago... What have you done? Did you find some solution?
Hi,
I've bought a 46PFL8007k/12 only 15 days ago. I've connected two external devices via hdmi (XBOX & Woxter Multimedia Center) and everything was perfect but, suddenly, the other day, when I turned on the Tv and I tried to play with the console, I was unable to do it because in the TV I've only got the 'No video signal' message...
Then, I tried to swap the Hdmi cables, the ports... But with the surprise that I hadn't no signal in any ports, doesn't matter what I connected to. Now, I can't see anything via hdmi!
Of course, I've tried to change ports, cables, check the devices with other tv (and it was OK), check the same devices with other connectivity (XBOX via Scart was ok)... And it seems like problem is located in every Hdmi ports of the TV... I don't know if it has some sense....
Also I tried to restart the tv with factory settings, just to see if hdmi ports has some 'memory' and tv records what it's connected to, and if you change the devices from one port to another it becomes crazy... But nothing....
This is really annoying... Does someone suffer something similar? I would be very grateful with some help, suggestion...
svanur08
Póstar: 2398
Re: Vandamál með að tengja inn ps4 við sjónvarp
Póstur af svanur08 »
ps4 glitch?
jardel
ÜberAdmin
Póstar: 1307
Póstur af jardel »
svanur08 skrifaði:ps4 glitch?
Ég held ekki
Það er fullt af öðrum í þessum vandræðum.
Það getur ekki verið um svona margar gallaðar tölvur í umferð.
svanur08
Póstar: 2398
búinn að prufa tengja við annað tv?
jardel
ÜberAdmin
Póstar: 1307
Póstur af jardel »
Er ekki búinn að prufa það ættla að prufa það eftir helgi.
Það merkilega við þetta er að þetta virkaði vel þegar ég var setja upp styllingarnar klukkuna og fleira svo allt i einu slekkur tölvan á sér og síðan þegar ég reyni að ræsa hana aftur kemur bara no signal þó svo hdmi kapall sé tengdur.
svanur08
Póstar: 2398
þetta er sennilega eitthvað hdmi handshake vandamál.
roadwarrior
Póstar: 539
Póstur af roadwarrior »
Prufaðu annan HDMI kapal.
jardel
ÜberAdmin
Póstar: 1307
Póstur af jardel »
roadwarrior skrifaði:Prufaðu annan HDMI kapal.
Er búinn að prófa 2.
Spurning um.að kaupa þriðja.
Oak
Póstar: 1590
Póstur af Oak »
https://www.youtube.com/watch?v=JgSI_q7q3VU
Er þetta kannski eitthvað sem hjálpar þér?
