Jæja ég er svona hægt og rólega að byggja upp smá server fyrir 2, bæði fyrir gögn og Plex. Hef eytt samtals 6.000 kr í þetta sem er frekar vel sloppið ef allt virkar þar að segjaSystem summary:
Cooler Master: Centurion 5,
Windows 7 Ultimate Edition Service Pack 1 build 7601 (64-bit),
1 x Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz,
4.0GB RAM,
NVIDIA GeForce 9400 GT,
75GB HDD,
400W PSU
General:
System Name: xxxxx-PC
Motherboard Manufacturer: Gigabyte Technology Co., Ltd.
Motherboard Name: P55-USB3
BIOS Manufacturer: Award Software International, Inc.
BIOS Version: F9
BIOS Release Date: 11/01/2010
CPU:
CPU manufacturer: GenuineIntel
CPU Type: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Socket: LGA1156
Lithography: 45nm
Physical CPU's: 1
Cores per CPU: 4
Hyperthreading: Disabled
CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 DEP PAE Intel64 VMX SMX Turbo FMA3
Clock frequencies:
- Measured CPU speed: 2665.6 MHz [Turbo: 3198.8MHz]
- Multiplier: x20.0 [Turbo: x24.0]
- Base Clock: 133.3 MHz
- Multiplier range: Min: x9, Max non turbo: x20 [Ratio: 4C: x21, 3C: x21, 2C: x24, 1C: x24]
Cache per CPU package:
- L1 Instruction Cache: 4 x 32 KB
- L1 data cache: 4 x 32 KB
- L2 cache: 4 x 256 KB
- L3 cache: 8 MB
TDP Limit: 95 Watts
TDC limit: 89 Amps
Memory
Total Physical Memory: 4087MB
Available Physical Memory: 2661MB
Memory devices:
Slot 1:
- 2GB DDR3 SDRAM PC3-10600
- Corsair VS2GB1333D4
- 1.5V, Clk: 666.7MHz, Timings 9-9-9-24 (@ Max. freq.)
Slot 2:
Graphics
Chip Type: GeForce 9400 GT
DAC Type: Integrated RAMDAC
Memory: 512MB
BIOS: Version 62.94.61.0.96
Driver provider: NVIDIA
Driver version: 9.18.13.4144
Driver date: 2-3-2015
Monitor 1: 1920x1080x32 60Hz (Primary monitor)
Disk drives
Disk drive: Model: Maxtor 6V080E0 ATA Device Serial: V20PPRVG (Disk: 0, Size: 74.53GB, Volumes: C)
Disk drive: Model: silicon-power USB Device Serial: N/A (Disk: 1, Size: 7.50GB, Volumes: N/A)
Network
Realtek PCIe GBE Family Controller (Speed: 100Mb/s) (MAC: 6C:F0:49:E0:78:CE)
Edimax 802.11n PCI Card
Verð að segja að ég er mjög sáttur með sjálfan kassan, sterkur og auðvelt að taka í sundur ánþess að plast brotni og hvað annað
Hugsaði mér að verða auðruvísi og hafa glans kóngabláan í stíl við móðurborð en ég átti svart spray þannig...
Ég ákvað að bíða með að lita HDD Festingarnar ef ég skildi velja annan lit á þær, þessi aflgjafi er líka bara til bráðarbirðar
Ég er svona reyna finna leið til að koma 120mm viftu að framan fyrir kælingu á HDD, endilega koma með hugmyndir
