Jæja þá er að prófa auglýsa Leikjatölvuna.
Tölvan inniheldur
Kassi; Bitfenix Prodigy (White)
Spec's
Materials Steel, Plastic
Colors (Int/Ext) Black/Black, White/White
Dimensions (WxHxD) 250 x 404 x 359mm
Internal Dimensions (WxHxD) 250 x 310 x 340 = 26.35 liters
Motherboard Sizes Mini-ITX
5.25" Drive Bays x 1 (removable)
3.5" Drive Bays x 5 (3 + 2 modular)
2.5" Drive Bays x 9 (5 + 2 + 1 +1 )
Cooling Front 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
Cooling Rear 120mm x 1 (included) or 140mm x 1(optional)
Cooling Top 120mm x 2 (optional)
PCI Slots x 2
I/O USB 3.0 x 2, HD Audio
Power Supply PS2 ATX (bottom, multi direction), PSU cage depth 180mm, max PSU depth 160mm
Extras FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
http://www.bitfenix.com/global/en/produ ... is/prodigy
______________________________________________________________________________________________________________
Fan controler: Bitfenix Recon (Svartur)
Spec's
Materials SofTouch™, ABS Plastic, Steel
Dimensions (WxHxD) 147 x 43 x 67mm
Form Factor 5.25" Drive Bay
Fan Channels x 5
Temperature Channels x 5
Max Watts / Channel 10W
Measurement Frequency Every 0.1 – 0.4 Seconds
Temperature Alarm Range 30℃-90℃
Temperature Range 0-100℃
Screen Size 4.7
http://www.bitfenix.com/global/en/produ ... n#overview
Móðurborð: EVGA z77 Stinger
Spec's
Based on Intel Z77 chipset
Memory
2 x 240-pin DIMM sockets
Maximum of 16GB of DDR3 2133MHz
Storage I/O
4 x Serial ATA 300MB/sec (2x Internal + 2x E-SATA) with support for RAID 0, RAID1, RAID 0+1, RAID5, RAID10 and JBOD
2 x Serial ATA 600MB/sec (2 Internal) with support for RAID 0 and RAID1
Expansion Slot
1 x PCIe x16, 1 x Mini PCIe
Multi I/O
Audio connector (Line-in, Line-out, MIC)
Integrated Peripherals
8 Channel High Definition (ALC889)
1 x 10/100/1000 (Intel 82574L)
Form Factor
Mini-ITX Form Factor
Length: 6.7in - 170.18mm
Width: 6.7in - 170.18mm
http://www.evga.com/Products/Product.as ... IB-E692-KR
Örgjafi: Intel i7 3770K
Spec's
Sökkull: 1155
Örgjörva týpa: Intel i7-3770K
Fjöldi kjarna: 4
Fjöldi þráða: 8
Örgjörvatíðni: 3.5GHz
Hámarks Turbo örgjörvatíðni: 3.9GHz
Flýtiminni: 8MB
DMI: 5GT/s
Instruction Set: 64-bit
Instruction Set Extensions: SSE 4.1/4.2, AVX
Framleiðslutækni: 22nm
Hámarksafl: 77W
Tækniupplýsingar um minni:
Hámarks minnisstærð: 32GB
Tegund minnis: DDR3-1333/1600MHz
Fjöldi minnisrása: 2
Hámarksbandbreidd minnis: 25.6GB/s
Tækniupplýsingar um skjástýringu:
Skjástýring á örgjörva: Intel HD Graphics 4000
Grunntíðni skjástýringar: 650MHz
Hámarkstíðni skjástýringar: 1.15GHz -
http://ark.intel.com/products/65523
Kæling: Corsair H100i
Spec's
Corsair H100i er lokuð vatnskæling með Corsair Link vöktunar og stjórnunarbúnaði
Aldrei verið eins auðvelt að setja upp vökvakælingu en H100i kemur með vökva áfyllt
Tvöföld kælieining með tveimur 120mm viftum eða alls 240mm kælifleti
Passar fyrir:
Intel sökla: 2011 / 1366 / 1156 / 1155 / 1150
AMD sökla: AM3+ / AM3 / AM2+ / AM2 / FM2 / FM1
Stærð: 120 x 275 x 27 mm
Viftuhraði: 2700 RPM
Loftstreymi: 77 CFM
Hljóð í viftu: 37.68 dBA
http://www.corsair.com/us/hydro-series- ... ooler.html
Skjákort: EVGA GeForce GTX 690!
Spec's
NVIDIA GTX 690
3072 CUDA Cores
915 MHz Base Clock
1019 MHz Boost Clock
Memory
4096 MB, 512 bit GDDR5
6008 MHz (effective)
384.52 GB/s Memory Bandwidth
Interface
PCI-E 3.0 16x
DVI-I, DVI-I, DVI-D, Mini-DisplayPort
Resolution & Refresh
240Hz Max Refresh Rate
Max Analog : 2048x1536
Max Digital : 2560x1600 (Dual Link DVI Only)
Operating System Support
Windows 8 32/64bit
Windows 7 32/64bit
Windows Vista 32/64bit
Requirements
Minimum of a 650 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 38 Amps.)
http://www.evga.com/Products/Product.as ... P4-2690-KR
Aflgjafi: Corsair AX860 (Á til Custom made kapla fyrir þennan aflgjafa sem smell passar í Prodigy'ið (eftir Mundivalur)
Spec's
Corsair Professional Platinum Series aflgjafli
-AX aflgjafarnir frá Corsair eru 80 PLUS Platinum vottaðir aflgjafar
-Modular aflgjafi svo þú notar bara þær snúrur sem þú þarft í hvert skipti
-140mm hljóðlát vifta með tvöföldum legum
-Bestu íhlutir sem eru í boði eru notaðir í AX línuna frá Corsair
Tækniupplýsingar
Stærð 150mm breitt, 86mm hæð og 160mm lengd
Afl 860W
ATX tengi 1
EPS Tengi 2
PCI-e Tengi 6
4 pinna tengi 8
SATA tengi 12
Floppi drifs tengi 2
MTBF 100.000 tímar
http://www.corsair.com/en/power-supply- ... r-psu.html
_______________________________________________________________________________________________________________________________________________________________
Vinnsluminni: Corsair Vengence(svört) 2x4GB 1600mHz
Spec's
Vinnsluminni fyrir borðtölvur
Corsair Vengeance vinnsluminnin eru hönnuð með yfirklukkara í huga.
RAM minni sérhannað fyrir mikil afköst og endingu.
Öflug kæliplata á vinnsluminni.
Stærð: 8GB (2x4GB)
Hraði: 1600MHz
Tegund: DDR3
Pinnafjöldi: 240 DIMM
Volt: 1.5v
Klukkusvörun: CL9
http://www.corsair.com/vengeance-8gb-du ... 600c9.html
SSD: Samsung EVO 250GB
Spec's
SSD er ein besta uppfærslan sem hægt er að fá sér fyrir fartölvu eða borðtölvu
Upplifðu ótrúlegan hraðamun á venjulegum harðdisk og SSD
SSD eru einnig sparsamir á rafmagn sem hentar vel í fartölvur
Tækniupplýsingar:
*Sequential Read Speed: Up to 540MB/s
*Sequential Write Speed: Up to 520MB/s
*Random Read Speed: Up to 97K IOPS
*Random Write Speed: Up to 66K IOPS
Einnig er 2x Corsair AF120 og 2x Corsair SP120 í kassanum
á til eina auka AF120 sem getur fylgt.
Hefði viljað selja Turninn í heilulagi, Möguleiki á partasölu ef boð berast í flesta hlutina.
Turninn kemur með uppsettu Windows 8. (Genuine lykill)
Ástæða sölu: Ég hef einfaldlega tekið mér ákvörðun um að taka mér pásu í öllum leikjum í bili og hef fest augu mín á fartölvu.
Skoða engin skipti nema á Pening eða Macbook!
Flesta allt keypt nýtt og í ábyrgð (Móðurborð og Kassi keypt hjá Highflow.nl)
Kostar nýtt um 421.200kr!
Mynd af Turninum:
Endilega hafið samband í PM! Allar ábendingar skulu eða Athugasemdir einnig í PM. Ég vill Halda Sölu þræðinum Hreinum og Fínum.
M-ITX Leikjaturn Prodigy GTX690 SSD i7 [SELT!]
Höfundur - Tölvutryllir
- Póstar: 692
- Skráði sig: Lau 04. Jún 2011 18:09
- Staðsetning: Rvk
MacTastic!
- Geek
- Póstar: 854
- Skráði sig: Lau 13. Okt 2012 23:43
- Staðsetning: 271 Mosfellssveit
Re: -Bitfenix Prodigy, i7 Ivy, EVGA GTX 690, SSD, o.fl.
0.0
Re: M-ITX Leikjaturn Prodigy GTX690 SSD i7
já sammála trausti164
Móðurborð með útgáfu 0.0
Rev.: 0.0 !!!!
En annars er þetta ofurtölva með "tiny" móðurborð.
Frítt Bump
Rev.: 0.0 !!!!
Frítt Bump
- Póstar: 1863
- Staðsetning: Akureyri
Upp fyrir sjúkum kassa.. það er einhver með augað á þessu skrímsli . upp upp .
Re: M-ITX Leikjaturn Prodigy GTX690 SSD i7 [SELT!]
Á hvað fór hann ef ég má spyrja ?? bara forvitni
þarft ekki að svara því.
- Tölvutryllir
- Póstar: 627
- Skráði sig: Sun 11. Mar 2012 21:57
- Staðsetning: ~/workrelatedthings
Jú, neyðum hann til þesskrissdadi skrifaði:Á hvað fór hann ef ég má spyrja ?? bara forvitni
Desktop
| i7 3770k @4.7GHz 1.35v | Corsair H100i | Corsair Vengeance CL9 4x4GB | MSI GeForce GTX 980 Twin Frozr V | MSI Z77A-G43 | Corsair GS 700w | Samsung 840 Evo 120GB | Seagate 5TB 7200rpm |
Server
| i7 920 @2.66GHz | Corsair Vengeance 4x4GB | Seagate 3TB 7200rpm | XFX R9 280x
Server
