Nvidia GTX 700 línan! _>Umræða<_
Xovius
Póstar: 1574
Póstur af Xovius »
Þá er ýmislegt lekið út um nýju 700 línuna frá Nvidia. Þar á meðal specs og myndir. Samkvæmt flestu sem ég hef lesið er líklegt að þetta komi út seinna í þessum mánuði!
Tomshardware.com skrifaði: What was previously rumored to be the GTX Titan LE appears to actually be the GTX 780, which will likely be based on a cut-down GK110 part. As such, it will feature 2,496 CUDA cores, 208 Texture Mapping Units, 40 Render Output Units, and 5 GB of GDDR5 memory that will run over a 320-bit memory interface.
Moving on, the GTX 770 will be based on the older GK104 part, essentially being a higher clocked GTX 680 with double the graphics memory slapped onto the PCB for a total of 4 GB. The GTX 760 Ti would likely be almost identical to the GTX 670, with perhaps slightly different clock speeds.
MSRP pricing for the GTX 780 is said to be between $499 and $599, the GTX 770 $399, and the GTX 760 Ti $299. While all of these details remain unconfirmed, it would be great if they are true.
http://www.tomshardware.com/news/Nvidia ... 22204.html" onclick="window.open(this.href);return false;
Svo eru myndir hérna http://www.techoftomorrow.com/2013/pc/l ... g-release/" onclick="window.open(this.href);return false;
Einhverjir hérna sem ætla að upgradea?
tveirmetrar
Póstar: 648
Skráði sig: Lau 31. Mar 2012 15:41
Re: Nvidia GTX 700 línan! _>Umræða<_
Póstur af tveirmetrar »
Langar að skoða 790 kortið þegar það kemur.
Hef haft augun á 690 Hydro Copper útgáfunni en ef það er svona stutt í 790 þá er það klárlega málið :D
Tveirmetrar* |Rmpg 6 Extr |7900x@4,8ghz |H150i Pro |1080ti Seahawk |32gb@4,0ghz |2x1tb m.2 960 Pro raid 0 |AX 1200i |View 71 |X34A Einnmeter* |Z97-K |4690k@4,5ghz |H150i |GTX 1080 |16gb@2,6ghz |1tb m.2 960 Pro |Crstl 570X |XR3501 Vinnumeter |4 Formula |3930k |970 |16gb |Q32 |BL32 Ferðameter: |MS Book 2 |i7 |GTX 1060 |16gb Hálfurmeter |NUC 7 |TV
Hvað? Skírir þú ekki tölvurnar þínar?
*RGB Mastered
Plushy
Póstar: 2259
Staðsetning: Grafarvogur
Póstur af Plushy »
Spurning um að selja kortið mitt og uppfæra þegar nýja línan kemur :)
demaNtur
Póstar: 1165
Staðsetning: 192.168.1.254
Póstur af demaNtur »
Ég held að ég sé barasta að fara kaupa notað 6xx kort fljótlega :D
i7 9700K - Asus ROG Strix Z390-I Gaming- Corsair Vengeance 2x16GB 3200MHz - GeForce 2070 Super
Asus 24.5" XG258Q 240hz - Glorious GMMK white ice - HyperX Cloud Alpha - Glorious Model-D - The Glorious 3XL
Xovius
Póstar: 1574
Póstur af Xovius »
demaNtur skrifaði:Ég held að ég sé barasta að fara kaupa notað 6xx kort fljótlega :D
Nákvæmlega það sem ég var að hugsa. Kannski að maður fari í 700 ef hún er eitthvað svakaleg en ef ekki þá á hun að minnsta kosti eftir að bumpa niður verðum á bæði nýjum og notuðum kortum af núverandi línum :P
Plushy
Póstar: 2259
Póstur af Plushy »
Xovius skrifaði:
Eða bara næla sér í 6xx frá einhverjum hérna sem er að uppfæra ^^
C3PO
Póstar: 336
Skráði sig: Mið 22. Mar 2006 09:10
Póstur af C3PO »
Hef hugsað mér að uppfæra í 780GTX kortið þegar það kemur út.
Ætlaði að uppfæra frá 580GTX i 680 GTX en fannst það ekki þess virði og of lítill munur.
Svo fannst mér skrítið að 680GTX kortið hafði einungis 256 bita Memory Interface á meðan mitt gamla er með 384 Memory Interface.
Og svo er Memory Bandwidth (GB/sec): = 192,2 á 680GTX kortinu en 192,4 á mínu gamla 580GTX.
Svo er náttúrulega meira sem að spilar inn í hraða og getu kortsins.
Vona bara að 780GTX verði eins og komið hefur fram, rétt slakari en TITAN kortið og á 500$, þá uppfæri ég 100%.
AM4 Ryzen-Gigabyte X470 AORUS Ultra Gaming - AMD Ryzen 7 2700X 3.7GHz, Turbo 4.3GHz, 8-kjarna
Corsair 16GB kit (2x8GB) DDR4 3200MHz, CL16, Vengeance LPX - Samsung 960 EVO M.2 500GB SSD,
Nvidia GTX 1080 Ti.
Skippó
Póstar: 136
Skráði sig: Mið 17. Apr 2013 18:01
Póstur af Skippó »
Hér er helvíti skemmtileg síða en samkvæmt henni þá er 161%a munur í Texel rate á 580 og 680.
http://www.hwcompare.com/12366/geforce- ... e-gtx-680/" onclick="window.open(this.href);return false;
Intel i7 7700k, Gigabyte G1 Gaming GTX1070, 2x8 gb DDR4, PRIME Z270-K, Thermaltake 730W 80 Plus, Fractal Design Define R5.
hkr
Póstar: 407
Skráði sig: Fös 23. Jan 2009 14:22
Póstur af hkr »
Skippó skrifaði:Hér er helvíti skemmtileg síða en samkvæmt henni þá er 161%a munur í Texel rate á 580 og 680.
Please note that the above 'benchmarks' are all just theoretical - the results were calculated based on the card's specifications, and real-world performance may (and probably will) vary at least a bit.
Skippó
Póstar: 136
Póstur af Skippó »
hkr skrifaði:
Jájá veit það alveg, en það er samt alveg hægt að miða við þetta ég meina það er "improvement" á skjákortunum annars væri enginn tilgangur í því að búa til ný.
Skippó
Póstar: 136
Póstur af Skippó »
hkr skrifaði:
Templar
Póstar: 541
Póstur af Templar »
TITAN SC enn kóngurinn virðist vera, áhugavert.
Ryzen 5950X - ASRock Taichi X570 - Palit 3090 Game Rock OC - G.Skill 32GB (4x8) DDR4 3733 CL14 - Samsung 970 Pro 1TB, 970 Evo Plus 1TB - PSU Corsair AXi 860W || DAC: Schiit Modi Multibit + Dimensions of Sound Speakers - LG CX 48" OLED || Lian Li Der Bauer Edition
vesley
Póstar: 4139
Staðsetning: við talvuna
Póstur af vesley »
Templar skrifaði:TITAN SC enn kóngurinn virðist vera, áhugavert.
Lítið áhugavert við það, TITAN á að vera kóngurinn þó að 700 serían komi út.
massabon.is
darkppl
Póstar: 535
Skráði sig: Mán 12. Júl 2010 21:40
Póstur af darkppl »
ég mun selja bæði 570 skjákortin mín..
I7-8700K|Corsair H-150i|Asus Maximus X Hero (Wifi) |32GB G.Skill Tridend Z RGB|GTX 1080ti |
Coolermaster Mastercase 5|
vikingbay
Póstar: 363
Skráði sig: Lau 01. Okt 2011 03:07
Póstur af vikingbay »
hlakka til :P
Xovius
Póstar: 1574
Póstur af Xovius »
Auðvitað, Titan á að vera ofurkortið. Aldrei hægt að búast við því að 780 sem kemur sennilega inn undir 100þúsund krónum fari að keppa alvarlega við 200þús króna kort.
Annars verður áhugavert að sjá hvernig performancið á 790 verður í samanburði við titaninn :)
AciD_RaiN
Tölvuskreytingameistari
Póstar: 3942
Staðsetning: Siglufjörður
Póstur af AciD_RaiN »
Einu líkurnar á að maður sé að fara í 700 línuna er að maður myndi þá næla sér í 2 stk af 770 ef þau verða til með 780 PCB. Ég hef náttúrulega EKKERT við það að gera þegar ég er bara að skoða facebook og vaktina en það er samt cool ;)
vikingbay
Póstar: 363
AciD_RaiN skrifaði:Einu líkurnar á að maður sé að fara í 700 línuna er að maður myndi þá næla sér í 2 stk af 770 ef þau verða til með 780 PCB. Ég hef náttúrulega EKKERT við það að gera þegar ég er bara að skoða facebook og vaktina en það er samt cool ;)
Facebook og Vaktin munu aldrei líta jafn vel út ;)
Moquai
Póstar: 591
Skráði sig: Fös 12. Nóv 2010 22:23
Staðsetning: 127.0.0.1
Póstur af Moquai »
Öss, ætli ég fari ekki frá 580 upp í 760 eða ehv.
GTX580 er ótrúlega hávært og heitt kort.
Samsung S27A950D 27" 120Hz - NZXT Phantom - GTX 1060 - i5 3570k @ 4.70GHz /w Noctua NH-D14 - Mushkin 4x4GB Redline 1866MHz - MSI H77MA-G43 - Sennheiser HD 598 /m Xonar STX Essence
Xovius
Póstar: 1574
Póstur af Xovius »
Moquai skrifaði:Öss, ætli ég fari ekki frá 580 upp í 760 eða ehv.
Mitt var nú allsekkert hávært, reyndar með Twin FrozrII cooler.
Verður gaman að sjá hvað fyrirtækin gera með coolers á nýju kortin. Fyrst að allt er með þessum vapour chambers nú þegar.
Skippó
Póstar: 136
Póstur af Skippó »
Er það staðfest að 700 línan komi út núna í maí?
mjámjá
Póstar: 45
Skráði sig: Fim 17. Jan 2013 23:21
Póstur af mjámjá »
veit einhver hérna eitthvað um 8000 ati seríuna?
hjalti8
Póstar: 353
Skráði sig: Sun 13. Mar 2011 13:03
Póstur af hjalti8 »
mjámjá skrifaði:veit einhver hérna eitthvað um 8000 ati seríuna?
amd munu sennilega sleppa 28nm refresh og fara beint í 20nm kort sem verður þá ekki fyrr en í lok árs eða snemma á næsta ári:
http://www.techpowerup.com/183704/amds- ... lands.html" onclick="window.open(this.href);return false;
http://www.xbitlabs.com/news/other/disp ... eport.html" onclick="window.open(this.href);return false;
þetta eru samt allt bara rumors..
Xovius
Póstar: 1574
Póstur af Xovius »
Skippó skrifaði:Er það staðfest að 700 línan komi út núna í maí?
Held að það sé hvergi officially staðfest en flest sources virðast vera nokkuð viss um það.
mercury
Póstar: 3298
Póstur af mercury »
mögulega hægt að flassa 680 í 770.
http://www.guru3d.com/news_story/flash_ ... x_770.html" onclick="window.open(this.href);return false;
