endanleg ákvörðun á móbói
BlitZ3r
Póstar: 450
Skráði sig: Sun 06. Jún 2004 04:47
Staðsetning: Westmannaeyjar
Póstur af BlitZ3r »
Eins og þið hafið séð þá er ég með Mesta RUSL móðurborð í veröldinni og mig langar nú að kaupa nýtt. en er í vafa um hvaða þannig að hér eru þau sem koma til greina:
Abit Ic7-Max3 Intel 875P Chipset Pentium 4 Mainboard Dual SATA RAID Dual DDR 400, AGP Pro 8X, OTES, ABIT Engineered™
Abit Ic7 Intel 875 Chipset Pentium 4 Mainboard Dual SATA RAID, DUAL DDR 400, AGP 8X, USB 2.0 SoftMenu™ Technology
Abit Ai7 Intel 865PE Chipset Pentium 4 Mainboard FSB 800, Dual DDR 400, SATA RAID, AGP 8X ABIT Engineered
og hver er munurinn á agp 8xpro og ekki pro og hvað er best miðaðvið verð.Og er ekki bara munurinn á 865pe og 875 að 875 hefur pat? meigið líka koma með önnur móðurborð ef þið viljið.
BlitZ3r > ByzanT-
Intel p4 2.6 @ 3.06 MSI 848p-Neo 2x256mb kingston 400mhz 120gb S-ATA WD diskur PowerColor RADEON 9800 PRO 256mb
Revenant
Póstar: 992
Póstur af Revenant »
Smá copy paste héðan:
If you want to overclock-----and can find PC4000 with good timings and Low voltage requirements----the IC7 is a clear winner.
It is a great overclocker and does PAT as well as top settings in GAT with ease.
But the sound is not as good and you have to buy a Nic card for it-----and it's usually about $10 more expensive----more when you factor in the Nic.
The AI7 has everything----is cheaper----and overclocks very well----but you have to "fiddle" with it to enable PAT and is VERY touchy on GAT settings.
Look at my signature-----I got those settings on an IC7 without even trying very hard.....
But the AI7 was more fun to play with.
Kind of up to you------if you aren't going to overclock------I'd go the AI7----great performance, reliability and sound for $25 cheaper.
demigod
Póstar: 255
Skráði sig: Þri 23. Mar 2004 00:25
Póstur af demigod »
eru þessi borð til hérna á íslandi ?
ef svo er copy paste síðurnar
"Walking on water and developing software from a specification are easy if both are frozen." Edward V. Berard
BlitZ3r
Póstar: 450
Póstur af BlitZ3r »
mesta buggið við ic7 er að það er ekkert netkort. en mér líst best á max3
borðið vegna otes kælingarinnar en verst á ai7 vegna asnarlegri hönnun á sokket er snúið 45° og líka vegna 865pe kubbasetsins
BlitZ3r > ByzanT-
ParaNoiD
Póstar: 307
Skráði sig: Fim 26. Feb 2004 21:08
Póstur af ParaNoiD »
IC7 er komið í Hugver með Gigabyte lan korti
... IC7-G heitir það þá :P
frumlegt finnst ykkur ekki ;)
Steini
Póstar: 358
Skráði sig: Fim 15. Apr 2004 22:36
Staðsetning: Grafarvogur
Póstur af Steini »
Ég er með ic7-g, fínt borð
WarriorJoe
Póstar: 158
Skráði sig: Mið 12. Mar 2003 11:38
Staðsetning: behind you
Póstur af WarriorJoe »
huh.. Ég er með Ic7-max3 og það er með netkorti?
Borð sem start.is lét mig fá, nýtt borð semsagt..
P4 3.0 ghz @ 3.5 * Abit IC7-Max3* 2x 512 MB Kingston Hyperx PC3200
Steini
Póstar: 358
Póstur af Steini »
Svipað sem gerðist hjá mér, keypti ic7 og var eitthvað vesen og þurfti að fá nýtt borð og fékk ic7-g
BlitZ3r
Póstar: 450
Póstur af BlitZ3r »
fyrir þá sem vita ertu að fá eitthvað performace boost við að taka ic7-max3 heldur en ic7-g
BlitZ3r > ByzanT-
