Computer Shop
Computer Shop
Hello , can somebody tell me if in Att.is they can setup your computer ? I mean if they can put everyting together after i will buy everything ? Please help
Re: Computer Shop
Yes they can if you buy everything from them
Re: Computer Shop
Yea , i want to buy whole computer setup. Hey , and you know for how much money they do it ???
Re: Computer Shop
No I am not sure, I think you might be able to get them to do it for free, because you are buying everything from them.
Re: Computer Shop
Ok , thanks for a help
Re: Computer Shop
They must because im buying setup over 500,000 so you know
I think 4x hd 7970 will be good enough for next 10 years gaming
- Ofur-Nörd
- Póstar: 228
- Skráði sig: Mán 02. Jan 2012 01:18
- Staðsetning: hafnarfijorden
Re: Computer Shop
Isn't 2 more then enough, and when games will require more power you can buy more for much lesser money?Darqu skrifaði:They must because im buying setup over 500,000 so you knowI think 4x hd 7970 will be good enough for next 10 years gaming
HAF 912 PLUS|i5 3570k|Msi 7850 twin frozr III |Asus P8z77-VLX |8GB Mushkin Blackline 1600 MHz|2TB Seagate|CX600 V2|Coolermaster Hyper 212+//Logitech z523|Logitech G500
- Póstar: 338
- Skráði sig: Fös 14. Sep 2012 10:54
- Staðsetning: Garðabær
Re: Computer Shop
500,000 is a lot of money, I recommend buying a little less now and upgrade later in maybe 5 years or so. That way you will most likely get more value. 4x 7970 is a bit overkill at the moment and when this kind of technology gets cheaper and cheaper almost every day, then i do feel like its unnecessary to spend that much money on a rig. Of course it depends on the usage of which you are going to use it. But if you are mostly going to be gaming, then I would recommend going a little cheaper.
- Tölvuskreytingameistari
- Póstar: 3942
- Skráði sig: Lau 22. Nóv 2008 11:14
- Staðsetning: Siglufjörður
Re: Computer Shop
Overkill is awesome but in my opinion 2-3 GPUs look much better then 4... Any color theme you have in mind? Could you tell us what other hardware you're gonna get?
- Póstar: 3697
Re: Computer Shop
I don't think that you would get very far running an ATI 9800 card today, even if you could run 4 of them at the same time.Darqu skrifaði: I think 4x hd 7970 will be good enough for next 10 years gaming
