**SELD**MSI GX640 fartölva til sölu
er með MSI GX640 leikjafartölvu, mjög flott vél.
örgjörvi: Intel Core i5 2,27GHz
vinnsluminni; DDR3 4GB
skjákort: ATI Readon HD5850 1GB
harði diskur: seagate 500GB
hljóðkort: realtek HD 7,1
skjár: 15,4" 1680x1050 glossy
Batterý: 2-3tímar 9cellu(held ég)
nýuppsett á windows 7 ultimate 64bit
3x USB / 1x HDMI / 1x VGA / kortalesari og fl..
keypti vélina notaða á bland.is
samkvæmt fyrri eiganda er hún 1árs og 2mánaða
ekki í ábyrgð og fylgir eingin nóta með
tölvansjálf lítur mjög vel út, lítið af rispum.
hún á það til að hitna svoldið, en ekkert alvarlegt.
VERÐ: 100þús TILBOÐ 75þ
MSI GX640 / 15,4" 1680x1050 / Intel Quad I5 2,27GHz / ATI HD5850 1GB / DDR3 2x2GB / seagate 500GB / windows 7 ultimate
Re: MSI GX640 fartölva til sölu
- FanBoy
- Póstar: 785
- Skráði sig: Lau 14. Júl 2012 22:36
- Staðsetning: 404 - Location Not found.
Hérna er linkur á review.
http://www.notebookcheck.net/Review-MSI ... 776.0.html" onclick="window.open(this.href);return false;
notebookcheck.net skrifaði: The GX640 has been optimised for high performance, with little thought for anything else. The results are obvious: high internal and external temperatures (with the GPU reaching 107°C) and a lot of system noise. Further weak points are the GX640's disappointing sound quality and its not very bright display, with particularly limited viewing angles. And why MSI is still using this keyboard in its models is a mystery; it is insultingly bad, even after a long time spent getting used to it.
But the 15-inch gaming notebook also has some good features. For instance, the compact body with its high-quality brushed aluminium surfaces, the very fast hard drive, good touchpad, and wide range of ports, and the black gaming mouse that comes with it. Its biggest strength, of course, is its breathtaking gaming performance - for a notebook, that is. Thanks to its high clock speed and lightning-fast GDDR5-VRAM, the ATI Mobility Radeon HD 5850 even triumphed over Nvidia's top model, the GeForce GTX 285M, in our benchmarks.
When all is said and done, we would not feel comfortable recommending the MSI GX640 because of its many failings. If you are looking for a more balanced gaming package, you might like to consider rival products like the Asus G73J. But it must be said that the GX640 does not fail to deliver first-class gaming performance.
takk fyrir þetta
uppmeðidda
tilboð 75þ i smá tíma
Re: "TILBOÐ"MSI GX640 fartölva til sölu
*Dual core
Samsung Series 7 - Intel i7 3615QM - 8gb 1600hz - 1tb hd - GeForce GT630m
afhverju koma upp 4 kjarnar í bæði speedfan og task manager ?Unnaro skrifaði:*Dual core
Þú ert væntanlega með þennan örgjörva: http://ark.intel.com/products/43537/Int ... e-2_26-GHz" onclick="window.open(this.href);return false;Sphinx skrifaði:afhverju koma upp 4 kjarnar í bæði speedfan og task manager ?Unnaro skrifaði:*Dual core
Hann er með 4 þræði en 2 kjarna.
upp með þettaa
- FanBoy
- Póstar: 785
Ahh já svona eins og I3, Ég hélt samt að allir I5 væru 4 kjarna?Unnaro skrifaði:Þú ert væntanlega með þennan örgjörva: http://ark.intel.com/products/43537/Int ... e-2_26-GHz" onclick="window.open(this.href);return false;Sphinx skrifaði:afhverju koma upp 4 kjarnar í bæði speedfan og task manager ?Unnaro skrifaði:*Dual core
ttt
vantar engum flotta fartölvu fyrir lítinn pening ???
- </Snillingur>
- Póstar: 1025
- Skráði sig: Lau 27. Mar 2010 18:16
- Staðsetning: Terra
Re: 75þ!!!!!MSI GX640 fartölva til sölu
flott tölva og frábært verð! thumbs up
MSi z270 Tomahawk | i7 7700k | Msi GTX 1060 Gaming X 6GB | 16GB 3000mhz Corsair vengeance | Samsung 750 Evo 120Gb | WD Black Caviar 640Gb | BenQ G2420HDB | HAF 912 Plus | Og það er alltaf eitthvað hljóð í bílnum mínum...
þetta er mikið eldri tölva þar sem flestar síður sýna speca frá 2010
og hver er ástæða fyrir sölu?
Vantar bara peningtanketom skrifaði:þetta er mikið eldri tölva þar sem flestar síður sýna speca frá 2010
tölvan fer ekki undir 75þ ef fólk er ekki að ná því..
70þ ef hun fer um helgina..
- FanBoy
- Póstar: 785
Sphinx skrifaði:tölvan fer ekki undir 75þ ef fólk er ekki að ná því..
Hún er búin að vera hérna síðan octóber,Sphinx skrifaði:70þ ef hun fer um helgina..
upp fer á 70þ
upp hæðsta boð 63þ
- Græningi
- Póstar: 41
- Skráði sig: Mið 02. Jan 2013 15:23
Ok, ef hæðsta boð er 63 þúsund, þá býð ég 50 þúsund staðgreitt á morgun.
- En þegar þú segir ofhita, er það að hafa mikil áhrif á tölvuna?
