Hjálp með að tengja sound úr tölvu í heimabíómagnara.
Aimar
ÜberAdmin
Póstar: 1311
Skráði sig: Mið 01. Sep 2004 09:43
Staðsetning: 201
Póstur af Aimar »
http://www.pioneer.eu/uk/products/archi ... media.html" onclick="window.open(this.href);return false;
Main Features VSX-415-S
Output Power per Channel 100W
Impedance at Output Level 8 Ω
Signal / Noise Ratio 88 / 64 db
Tuner Pre-set Stations 30
Remote Control SR
Power Consumption (in use / standby) 220W / 0.5W
Weight 8.7 kg
Dimensions (W x H x D) 420 x 158 x 394.5 mm
Surround Sound Formats VSX-415-S
Dolby Digital Yes
Dolby Pro Logic Yes
Dolby Pro Logic II Yes
DTS Yes
Construction VSX-415-S
Pioneer Hybrid Amplification Yes
Digital Signal Processor Motorola 150 MIPS 48-bit Processing
Amplifier Specifications VSX-415-S
A/D Converter 96 kHz/24-Bit (2-channel)
Input & Output connections VSX-415-S
Composite Input/Output 3/2
Digital Coaxial Input 2
Multi-Channel Input 5.1 ch (DVD)
Pre-amp Output Yes (SW)
Audio Features VSX-415-S
Loudness Yes
Midnight Listening Mode Yes
Source Direct Yes
Surround Modes 8 + 1
Power Output VSX-415-S
Input (Sensitivity/Imp.): LINE 200 mV / 47 kOhm
Signal-to-Noise Ratio: LINE (DIN) 88 / 64 dB
Power Requirements AC 220 - 240 V, 50/60 Hz
Power output per channel 100W/ch
Frequency Response: LINE 5 - 100 000 Hz, +0 / -3 dB
D/A Converter 192 kHZ/24-Bit
Speaker A/B A only
Bass/Treble Tone Controls Yes
er með þennan heimabíómagnara og síðan þetta móðurborð
http://www.gigabyte.com/products/produc ... id=3421#sp
Realtek ALC892 codec
High Definition Audio
2/4/5.1/7.1-channel
Support for Dolby Home Theater
Support for S/PDIF In/Out
Support for CD In
Spurningin er.
Hvernig tengi ég þetta fyrir 5.1 kerfi sem ég er með. (miðju, 2xfront, 2x aftur og bassabox)?????
GPU: Asus Turbo 2080 ti - GA z590 gaming X - Intel Core i7 11700k - Corsair Rm750x - Noctua-U12S - iCUE 465X RGB Mid-Tower- AORUS RGB Memory DDR4 16GB x4 3733MHz - Samsung 970 EVO 1TB M.2 2280 SSD - Win 10 Pro 64bit - ASUS ROG Swift Curved PG348Q @ 100mhz
AntiTrust
Póstar: 6292
Re: Hjálp með að tengja sound úr tölvu í heimabíómagnara.
Póstur af AntiTrust »
Bitstream-ar hljóðið úr tölvunni yfir Optical/Toslink tengið og lætur magnarann um að vinna úr hljóðinu.
Σ = 29Ghz, 96GB DDR, 54TB.
Oak
Póstar: 1590
Póstur af Oak »
Færð þér ljósleiðara á milli optical snúru.
hagur
Póstar: 2917
Póstur af hagur »
Svosem ekki miklu við þetta að bæta, en snúran sem þig vantar er þessi:
http://www.computer.is/vorur/3220/" onclick="window.open(this.href);return false;
Tengir í "Opt" tengið undir "Digital in" á magnaranum og svo í samsvarandi tengi á móðurborðinu.
Aimar
ÜberAdmin
Póstar: 1311
Staðsetning: 201
Póstur af Aimar »
jæja,búin að tengja þetta.
en fæ ekk hljoðið til að virka.
ef ég hef speakers (default) tengda kemur sound en ef ég stilli á
tv/sat á magnara og stilli á digidal audio (default) í tölvunni , þá kemur ekkert.
Hugmyndir?
Aimar
ÜberAdmin
Póstar: 1311
Staðsetning: 201
Póstur af Aimar »
Aimar skrifaði:Mynd
Hugmyndir?
komið þetta var magnarastilling.
