Farice í ruglinu?
dori
Póstar: 3567
Farice í ruglinu?
Póstur af dori »
Ég fæ alltaf timeout þegar ég reyni að tengjast http://rctech.net" onclick="window.open(this.href);return false;. Ég kíkti auðvitað á downforeveryoneorjustme.com og þar er mér bent á að hún líti út fyrir að vera uppi. Svo ég skoða traceroute fyrir það og þá fæ ég svona líka skemmtilegt:
halldor$ traceroute rctech.net
traceroute to rctech.net (98.158.194.160), 64 hops max, 52 byte packets
 1  192.168.30.254 (192.168.30.254)  2.045 ms  0.703 ms  0.694 ms
 2  178.19.50.25 (178.19.50.25)  1.579 ms  1.606 ms  1.393 ms
 3  * * *
 4  * * *
 5  * * *
 6  157.157.255.187 (157.157.255.187)  5.400 ms  2.847 ms  2.972 ms
 7  31.15.115.0 (31.15.115.0)  7.279 ms  4.505 ms  2.680 ms
 8  31.15.113.3 (31.15.113.3)  42.199 ms  41.796 ms  41.225 ms
 9  31.15.113.6 (31.15.113.6)  50.578 ms  50.507 ms  52.169 ms
10  31.15.113.7 (31.15.113.7)  46.677 ms  46.464 ms  46.686 ms
11  31.15.113.6 (31.15.113.6)  55.720 ms  56.483 ms  55.790 ms
12  31.15.113.7 (31.15.113.7)  51.731 ms  51.300 ms  51.521 ms
13  31.15.113.6 (31.15.113.6)  60.770 ms  62.499 ms  61.640 ms
14  31.15.113.7 (31.15.113.7)  57.027 ms  56.548 ms  57.121 ms
15  31.15.113.6 (31.15.113.6)  68.620 ms  66.785 ms  66.415 ms
16  31.15.113.7 (31.15.113.7)  63.484 ms  62.033 ms  62.401 ms
17  31.15.113.6 (31.15.113.6)  72.100 ms  71.606 ms  71.775 ms
18  31.15.113.7 (31.15.113.7)  68.197 ms  68.630 ms  67.390 ms
19  31.15.113.6 (31.15.113.6)  82.959 ms  76.798 ms  76.614 ms
20  31.15.113.7 (31.15.113.7)  73.260 ms  73.860 ms  72.340 ms
21  31.15.113.6 (31.15.113.6)  81.623 ms  82.099 ms  81.716 ms
22  31.15.113.7 (31.15.113.7)  77.962 ms  78.375 ms  78.129 ms
23  31.15.113.6 (31.15.113.6)  86.953 ms  88.204 ms  87.012 ms
24  31.15.113.7 (31.15.113.7)  82.912 ms  82.818 ms  82.731 ms
25  31.15.113.6 (31.15.113.6)  92.414 ms  96.917 ms  95.218 ms
26  31.15.113.7 (31.15.113.7)  88.520 ms  88.200 ms  88.563 ms
27  31.15.113.6 (31.15.113.6)  98.530 ms  98.133 ms  97.792 ms
28  31.15.113.7 (31.15.113.7)  95.468 ms  93.089 ms  93.827 ms
29  31.15.113.6 (31.15.113.6)  103.883 ms  103.336 ms  102.748 ms
30  31.15.113.7 (31.15.113.7)  98.908 ms  98.885 ms  104.126 ms
31  31.15.113.6 (31.15.113.6)  107.753 ms  107.779 ms  107.955 ms
32  31.15.113.7 (31.15.113.7)  103.837 ms  103.976 ms  103.667 ms
33  31.15.113.6 (31.15.113.6)  113.211 ms  113.000 ms  114.153 ms
34  31.15.113.7 (31.15.113.7)  108.882 ms  109.024 ms  109.148 ms
35  31.15.113.6 (31.15.113.6)  118.259 ms  118.183 ms  118.383 ms
36  31.15.113.7 (31.15.113.7)  114.228 ms  114.159 ms  114.368 ms
37  31.15.113.6 (31.15.113.6)  125.777 ms  123.426 ms  123.684 ms
38  31.15.113.7 (31.15.113.7)  119.526 ms  119.360 ms  119.687 ms
39  31.15.113.6 (31.15.113.6)  128.833 ms  128.666 ms  129.237 ms
40  31.15.113.7 (31.15.113.7)  124.754 ms  124.633 ms  125.820 ms
41  31.15.113.6 (31.15.113.6)  134.651 ms  134.027 ms  134.059 ms
42  31.15.113.7 (31.15.113.7)  129.740 ms  129.919 ms  129.915 ms
43  31.15.113.6 (31.15.113.6)  139.328 ms  139.335 ms  139.310 ms
44  31.15.113.7 (31.15.113.7)  135.101 ms  134.963 ms  134.895 ms
45  31.15.113.6 (31.15.113.6)  144.619 ms  147.204 ms  144.271 ms
46  31.15.113.7 (31.15.113.7)  141.937 ms  140.219 ms  140.662 ms
47  31.15.113.6 (31.15.113.6)  149.607 ms  149.763 ms  149.692 ms
48  31.15.113.7 (31.15.113.7)  145.657 ms  145.442 ms  146.209 ms
49  31.15.113.6 (31.15.113.6)  160.971 ms  173.254 ms  155.658 ms
50  31.15.113.7 (31.15.113.7)  150.905 ms  150.901 ms  150.706 ms
51  31.15.113.6 (31.15.113.6)  160.106 ms  160.227 ms  160.050 ms
52  31.15.113.7 (31.15.113.7)  156.604 ms  155.995 ms  155.927 ms
53  31.15.113.6 (31.15.113.6)  165.921 ms  172.310 ms  166.521 ms
54  31.15.113.7 (31.15.113.7)  161.284 ms  161.387 ms  161.830 ms
55  31.15.113.6 (31.15.113.6)  171.457 ms  170.659 ms  170.681 ms
56  31.15.113.7 (31.15.113.7)  166.452 ms  166.284 ms  166.305 ms
57  31.15.113.6 (31.15.113.6)  175.864 ms  175.959 ms  176.588 ms
58  31.15.113.7 (31.15.113.7)  171.557 ms  171.437 ms  171.788 ms
59  31.15.113.6 (31.15.113.6)  181.359 ms  181.093 ms  180.857 ms
60  31.15.113.7 (31.15.113.7)  176.761 ms  176.678 ms  176.732 ms
61  31.15.113.6 (31.15.113.6)  186.374 ms  186.026 ms  186.394 ms
62  31.15.113.7 (31.15.113.7)  182.218 ms  181.878 ms  182.111 ms
63  31.15.113.6 (31.15.113.6)  191.474 ms  192.365 ms  191.573 ms
64  31.15.113.7 (31.15.113.7)  187.256 ms  187.123 ms  187.201 ms
31.15.113.6 og 7 eru báðar skráðar á Farice
halldor$ whois 31.15.113.6
# Query terms are ambiguous.  The query is assumed to be:
#     "n 31.15.113.6"
# Use "?" to get help.
# The following results may also be obtained via:
# http://whois.arin.net/rest/nets;q=31.15.113.6?showDetails=true&showARIN=false&ext=netref2
NetRange:       31.0.0.0 - 31.255.255.255
CIDR:           31.0.0.0/8
OriginAS:
NetName:        RIPE-31
NetHandle:      NET-31-0-0-0-1
Parent:
NetType:        Allocated to RIPE NCC
Comment:        These addresses have been further assigned to users in
Comment:        the RIPE NCC region. Contact information can be found in
Comment:        the RIPE database at http://www.ripe.net/whois
RegDate:
Updated:        2010-05-18
Ref:            http://whois.arin.net/rest/net/NET-31-0-0-0-1
OrgName:        RIPE Network Coordination Centre
OrgId:          RIPE
Address:        P.O. Box 10096
City:           Amsterdam
StateProv:
PostalCode:     1001EB
Country:        NL
RegDate:
Updated:        2011-09-24
Ref:            http://whois.arin.net/rest/org/RIPE
ReferralServer: whois://whois.ripe.net:43
OrgAbuseHandle: RNO29-ARIN
OrgAbuseName:   RIPE NCC Operations
OrgAbusePhone:  +31 20 535 4444
OrgAbuseEmail:  hostmaster@ripe.net
OrgAbuseRef:    http://whois.arin.net/rest/poc/RNO29-ARIN
OrgTechHandle: RNO29-ARIN
OrgTechName:   RIPE NCC Operations
OrgTechPhone:  +31 20 535 4444
OrgTechEmail:  hostmaster@ripe.net
OrgTechRef:    http://whois.arin.net/rest/poc/RNO29-ARIN
# ARIN WHOIS data and services are subject to the Terms of Use
# available at: https://www.arin.net/whois_tou.html
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: this output has been filtered.
%       To receive output for a database update, use the "-B" flag.
% Information related to '31.15.113.0 - 31.15.113.127'
inetnum:         31.15.113.0 - 31.15.113.127
netname:         FARICE
descr:           Farice Infrastructure
country:         is
admin-c:         OO655-RIPE
tech-c:          OO655-RIPE
status:          ASSIGNED PA
mnt-by:          MNT-FARICE
source:          RIPE # Filtered
person:          Orn Orrason
address:         Farice hf
address:         Smáratorg 3
address:         201 Kópavogur
address:         Iceland
phone:           +354820500
e-mail:          orn.orrason@radlegging.is
nic-hdl:         OO655-RIPE
mnt-by:          OO42218-MNT
% This query was served by the RIPE Database Query Service (proxy) version 1.4.6 (WHOIS4)
Ég er illa að mér í netkerfismálum, er þetta ekki einhver bilun hjá þeim?
