[TS]ThinkPad Edge E520
tanketom
Póstar: 1015
Póstur af tanketom »
ThinkPad Edge E520
Sælir vaktarar.
jæja ákvað að láta hana til sölu vegna þess að ég hef eiginlega ekki not fyrir hana. Hún er já ekki mikið notuð og það eru engar rispur á henni, kemur í kassanum.
ábyrð fylgir og var keyft í budin.is, Afhent 2011-08-31 17:24:08
• Örgjörvi: Intel® Core i5 Processor i5-2410M with dual core (2.30GHz), 3MB í flýtiminni
• Breiðtjaldsskjár: 15.6" HD með LED baklýsingu. Upplausn 1366x768
• Vinnsluminni: 8GB DDR3 1333MHz
• Harður diskur: 500GB Serial-ATA 7200sn
• Geisladrif: 8xDVD±RW Dual Layer skrifari
• Skjástýring: Intel HD Graphics 3000 með HDMI útgangi
• Þráðlaust netkort: 802.11a/g/n og 10/100/Gigabit netkort
• Rafhlaða: Li-ion rafhlaða: allt að 6klst ending
• Tengi: 3x USB2.0, eSATA tengi, Hljóð inn og út, VGA og HDMI tengi
• Vefmyndavél: Innbyggð 720P HD vefmyndavél
• Kortalesari: Innbyggður kortalesari les flestar tegundir minniskorta
• Stýrikerfi: Windows 7 Professional 64-bita
• Þyngd aðeins 2.35kg
specifications
Audio
High Definition (HD) Audio
Conexant 20671 codec
Stereo speakers
Mono digital microphone
Combo audio/mic jack
Keyboard
Embedded numeric keypad and integrated UltraNav dual-pointing system with wide touch pad below keyboard, Tap Zones, scrolling regions label, multi-touch; and TrackPoint and customized touch pad for the ultimate in pointing flexibility.
ThinkVantage button, individual speaker volume up, down, and mute buttons, mic mute button
The keyboard has a Fn key which is a special key and is located in the lower left corner. The Fn key allows the user to instantly activate the following operational features by pressing the Fn key and a designated function key:
Standby/Suspend/Hibernation
Switching between Display device
Multimedia
Fingerprint reader is integrated into the palm rest of the ThinkPad notebook computer to prevent unauthorized access to your notebook and data
Spill-resistant
Numeric Keypad
Memory
Mouse
TrackPoint® pointing device, Internet Scroll Bar
UltraNav™, wide touchpad below keyboard, Tap Zones, multi-touch
Processor
Intel® Core i5 Processor i5-2410M with dual core (2.30GHz), 3MB Cache
DDR3 memory controller (up to 1333MHz), Intel Turbo Boost 2.0, HT technology
Communications
Network
Intel Centrino Wireless-N 1000
Bluetooth 3.0 Wireless
Expansion
Bays
One 34-mm ExpressCard
4-in-1 Media Card reader slot
External ports
Three USB ports version 2.0
One USB 2.0/eSATA combo port
Additional connector supports the optional Port Replicator, advanced dock, and advanced mini-dock.
Audio ports
External stereo speakers or headphone
External monitor (VGA DB-15, HDMI)
USB 2.0 Lenovo Modem
Ethernet RJ-45 connectors for LAN connection
Operating environment
Physical specifications
For systems with a 395-mm (15.6-in) TFT display:
System:
Width: 380 +/-0.8 mm (14.96 in)
Depth: 248.5 +/-0.8mm (9.78 in)
Height: 29.3 - 33.7 mm (1.15 - 1.33 in)
Configured system weight: Starting at 2.4 kg (5.0 lb)
Environment:
Maximum altitude without pressurization: 3048 m (10,000 ft)
Temperature
At altitudes up to 2438 m (8000 ft)
Operating without any in drive: 5.0°C to 35.0°C (41°F to 95°F)
Operating with any in drive:10.0°C to 35.0°C (50°F to 95°F)
Non-operating: 5.0°C to 43.0°C (41°F to 109°F)
At altitudes above 2438 m (8000 ft)
Maximum temperature when operating under the unpressurized condition: 31.3°C (88°F)
Relative humidity:
Operating: 8% to 95%
Non-operating: 5% to 95%
Note: When you charge the battery pack, its temperature must be at least 10°C (50°F).
Accessories:
Please click here to find more accessories for your Lenovo system.
Look for the "Option Compatibility Matrix". Some of the links for the product in the Excel file are clickable and you will find more details on the website.
Note: All weight and dimensions are approximate.
Power
AC Adapter
AC adapter: This ac-to-dc converter supplies the necessary power to the computer. The ac adapter also charges the battery pack when it is installed in the computer.
Universal AC adapter: 90 W, 2-pin / 3-pin (Click here for more information)
Universal AC adapter: 65 W 2-pin/3-pin (Click here for more information)
Battery (Click here for more information)
Battery
The battery pack is an internal power source to the computer when the AC adapter is not available. The battery pack is rechargeable and is charged using the AC adapter with the system.
You can determine how much battery power remains by using the Fuel-Gauge ThinkPad utility program. This displays the percent charge remaining, whether one or two batteries are in the system.
A 6- or 9-cell Li-Ion battery pack is shipped with the system.
Supports optional Slice battery as second battery at bottom.
Battery life:
6-cell: up to 6.2 hours
Notes:
Battery life (and recharge times) will vary based on many factors including screen brightness, applications, features, power management, battery conditioning and other customer preferences.
Security
System
Power-on password
Hard disk password
Supervisor password
Security keyhole
Fingerprint reader on selected models, offers users a convenient solution, authenticate at system startup and log on to Windows with a swipe of your finger.
Password
A Power-on password (POP) protects the system from unauthorized use. If a POP is set, the password prompt appears:
Each time the system is turned on
When the system is returned to normal operation from suspend mode
A Supervisor Password provides a higher level of security than the POP. The Supervisor Password protects the system functions from being used by unauthorized users,and protects the hardware configuration from unauthorized modification. The Supervisor Password prompt appears:
When the BIOS setup screen is accessed.
A Hard Drive Password (HDP) protects hard drive data from unauthorized users. Once HDP is set, data on the hard drive cannot be accessed without the correct HDP. Because the HDP is stored in the hard drive, the data remains protected even if the hard drive is removed to another system. The HDP password prompt appears:
Each time the system is turned on.
Software
Operating system
Windows 7 Professional (64-bit)
Notes:
Previous versions of these operating systems are not supported.
Operating systems other than those preinstalled on the systems may not provide full-feature functionality
Storage
Optical drive
Ultrabay enhanced DVD/CD-RW combo drive
Hard drive features
500 GB, 5400rpm, 9.5mm high, SATA HDD
Man ekki alveg hvor það var 5400 eða 7200
500 GB, 7200rpm, 9.5mm high, SATA HDD
Supports one additional hard drive which can be used concurrently to offer expanded storage in the Ultrabay Slim Media Bay.
Although you can upgrade the hard drive, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay Slim hard drive adapter is designed to provide this flexibility with a second hard drive in the Ultrabay Slim.
The Hard Drive Active Protection system protects your hard drive when the shock sensor inside your ThinkPad computer detects a situation that could potentially damage the hard drive.
Note: Supported hard disk drives depend on the model.
Solid state drive features
80 GB Solid State Drive, MSATA
Fast, reliable, lightweight, and energy-efficient.
Faster data rates and boot-up times than a 7200 rpm mobile hard disk drive (HDD).
Very low failure rates.
Able to withstand harsher environmental and vibration conditions than a mobile HDD.
Consumes less battery power than a mobile HDD.
Significantly lighter than a mobile HDD.
Video
Display
15.6" HD LED-backlight display, Anti Glare
Notes:
Support for a external monitor is through VGA DB-15 connector
Support for digital monitor via HDMI (supporting HDCP to output protected content)
Support dual independent display
Maximum external resolution: 2048x1536 (VGA)@75Hz; 1920x1200 (HDMI)@60Hz
All displays are measured diagonally.
Graphic Controller
Video chipsets:
Notes:
einarharalds
Póstar: 13
Skráði sig: Fös 06. Ágú 2010 16:35
Re: [TS]ThinkPad Edge E520
Póstur af einarharalds »
Hvað viltu fá fyrir hana?
Sphinx
Póstar: 1186
Skráði sig: Mán 11. Maí 2009 21:06
Póstur af Sphinx »
Verð ?
MSI GX640 / 15,4" 1680x1050 / Intel Quad I5 2,27GHz / ATI HD5850 1GB / DDR3 2x2GB / seagate 500GB / windows 7 ultimate
tanketom
Póstar: 1015
Komið með raunsæ tilboð :catgotmyballs
væri líka ágætt að fá verðlöggur hingað til að meta hana
Sphinx
Póstar: 1186
Póstur af Sphinx »
keyptiru hana ekki á 120þ
56illi
Póstar: 2
Skráði sig: Fös 16. Mar 2012 08:44
Póstur af 56illi »
Heill og sæll.
Mig einmitt vanntar góða tölvu til að nota í skóla, þá er það spurningin , ég á Samsung Galaxy Tab 10.1, 16GB, 3G, WiFi + connection kit + bílrúðu standur (virkar á alla slétta fleti) , er í fullri ábyrgð, með kaupnótu og með auka kaskó trygginu , hvort þú hefðir áhuga á skiptum.
endilega hafðu samband ef þetta er einhvað sem þú hefur áhuga á
í email eða bara á spjallinu
Illugi56@gmail.com
tanketom
Póstar: 1015
Sphinx skrifaði:keyptiru hana ekki á 120þ
mikið rétt sphnix, var á einhverju 4 daga tilboði
56illi skrifaði:Heill og sæll.
Illugi56@gmail.com
Ég þakka boðið en ég hef ekkert við spjaldtölvu að gera..
KrissiK
Póstar: 902
Staðsetning: In le matrix
Póstur af KrissiK »
skoðaru skipti á borðtölvu ??
TURN:
- InWin GRone - Intel Core i7 6700K @ 4.0GHz - 16GB DDR4 2133Mhz - Gigabyte GA-Z170-HD3P (LGA1151) - EVGA Geforce GTX1070 8GB - 250GB Samsung EVO SSD - 3TB Seagate HDD
tanketom
Póstar: 1015
KrissiK skrifaði:skoðaru skipti á borðtölvu ??
ég á borðtölvu ;)
Nördaklessa
Póstar: 1025
Staðsetning: Terra
Póstur af Nördaklessa »
hvað vill kallinn fá fyrir hana?
MSi z270 Tomahawk | i7 7700k | Msi GTX 1060 Gaming X 6GB | 16GB 3000mhz Corsair vengeance | Samsung 750 Evo 120Gb | WD Black Caviar 640Gb | BenQ G2420HDB | HAF 912 Plus | Og það er alltaf eitthvað hljóð í bílnum mínum...
tanketom
Póstar: 1015
Nördaklessa skrifaði:hvað vill kallinn fá fyrir hana?
ég var að vonast eftir 90 - 100 en er kominn með tilboð uppá 70þ í hana
Þannig séð er það bara ekki neitt... Þótt að ég hafi fengið hana á svona lágu verði þá verðum við að miðað við hvað sambærilegar vélar kosta í dag.
Ég veit að sumir hugsa ''pff biddu hvaða djók er þetta'' En ef þið hugsið svo aðeins aftur, þið eru nánst að fá dúndur tölvu hérna sem er nánast ónotuð, hún kemur í kassanum og fylgir allt með.
skoðum aðeins hérna nokkrar týpur sem eru mikið dýrari en samt ekki jafn öflugar..
baam! lýtur nákvæmlega eins út en innihald = :thumbsd
http://www.netverslun.is/verslun/produc ... 1,560.aspx" onclick="window.open(this.href);return false;
baam! þið sjáið munin strax...
http://www.netverslun.is/Verslun/produc ... 5,560.aspx" onclick="window.open(this.href);return false;
baam! halló :uhh1
http://www.netverslun.is/Verslun/produc ... 6,560.aspx" onclick="window.open(this.href);return false;
Ooog hversu geeðveikt er þetta? Þótt ég myndi ný aldrei þora taka áhættuna á þessu þá á hún að þola þetta vel.
http://www.youtube.com/watch?v=d7cvi00OZDM" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?feature=en ... xsDRI8At4Q" onclick="window.open(this.href);return false;
tanketom
Póstar: 1015
this will be your best friend :troll
tanketom
Póstar: 1015
:popp
tanketom
Póstar: 1015
hún fer líklegast á miðvikudaginn :megasmile
tanketom
Póstar: 1015
upp með þetta :happy
Sphinx
Póstar: 1186
Póstur af Sphinx »
flottar vélar.. ég á eitt stykki :)
einarharalds
Póstar: 13
seld?
tanketom
Póstar: 1015
Jæja hún er kominn í sölu aftur eftir að hafa verið hjá Nýherja í margar vikur..
Netkortið var semsagt gallað og þurftu þeir að skifta um móðurborð í henni ;)
fannst alltaf netið vera eh skringilega hægt :hugenose en allt annað líf núna :happy
tanketom
Póstar: 1015
Sphinx
Póstar: 1186
Póstur af Sphinx »
tanketom skrifaði:Jæja hún er kominn í sölu aftur eftir að hafa verið hjá Nýherja í margar vikur..
taka þeir þetta að sér að skipta um þetta í ábyrgð ? þótt vélin se ekki keypt hjá þeim ? er nefnilega með eins vél
tanketom
Póstar: 1015
Sphinx skrifaði:
Eins og mínu tilfelli þá var þetta Framleiðslugalli og þá bera þeir ábyrð á henni, samkvæmt lögum.
Hún fór fyrst í gegnum nördan, en þegar þeir áttuðu sig á að þetta væri Framleiðslugalli þá var hún send þangað.
Segjum að þú myndir flytja sjálfur inn thinkpad tölvu, þá væri hún með 1 árs ábyrð hjá nýherja.
En þar sem þessi tölva er keyft af fyrirtæki hérna heima þá er hún með 2 ára ábyrð í gegnum nördin.is, en þar sem hún var ekki orðinn eldri en þetta, þá gátu þeir hent henni í nýherja.
Sphinx
Póstar: 1186
Póstur af Sphinx »
næs takk fyrir þetta
tanketom
Póstar: 1015
tanketom
Póstar: 1015
:happy
tanketom
Póstar: 1015
:guy
