Uninterruptible Power Supply UPS
Sinus Series Single Phase in/Single Phase out
Allt fylgir með: Manual, RS-232 kapall, geisladiskur og rack-festingar.
Myndir
http://myndahysing.net/upload/91295112385.JPG" onclick="window.open(this.href);return false;
http://myndahysing.net/upload/131295112386.JPG" onclick="window.open(this.href);return false;
Verð: Tilboð í pm.
SS 210 1 kVA
Voltage 160 - 280 VAC
Frequency 50 / 60 Hz. ± 5 %
Power Factor >0.98
OUTPUT
Output Power Factor 0.7
Voltage 220VAC / 230VAC
Voltage Regulation ±%2
Frequency 50 / 60 Hz (Auto Detection)
Frequency Regulation ±0,5%
Harmonic Distortion < 3 % (For Linaer Loads)
Crest Factor 3:1
Overload Capacity 100% - 120% for 60 seconds, 120% - 150% for 10 seconds
Whole efficiency >85%
Inverter efficiency >90%
Transfer Time 0ms
Outlets 3pcs IEC & 1pc Schuko Outlets
BATTERY
Type Maintenance-free lead acid batteries
Recharge Time Voltage 8 hours (to 90% of full capacity) 36VDC
Quantity 3 pcs 12V 7ah
Back Up Time Full Load 8 min Half Load 20 min
DISPLAY
LED Display line input, inverter, bypass, fault, overload, battery low, self-test, Load/Battery Level
ALARMS
Line Failure, Battery Low, Transfer To Bypass, Failure Events
PROTECTION
short circuit, over temperature, overload, high voltage, battery low
COMMUNICATION
Interface (Communication Port) RS-232
Monitoring and Management Software standard
ENVIRONMENT
Temparature 0°C - 40°C
Humidity 0%-95%
Noise Level (1m Distance) <45dBA
Protection Class IP20
PHYSICAL SPECIFICATIONS
Tower Type
Net Weight(kg) 15
Dimensions (mm) WxHxD 147x401x223
STANDARDS EN 62040-1-1 (safety), EN 62040-2 (EMC)
sbr. http://www.informups.com/sinus_1_phase_technics.html" onclick="window.open(this.href);return false;
[TS] UPS Sinus Series SS-210 1 kVA
TI UltraSparc IIe (Hummingbird)
Re: [TS] UPS Sinus Series SS-210 1 kVA
bump
bumb
Hvað eru svona UPSar að fara á í dag?
