Skjávarpinn er eins og nýr, það fylgir með honum loftfesting, rafmagnssnúra og vga snúra.
Product Features
* Texas Instruments DDR DLP Technology
* Short-Throw Zoom Lens
* New DVI-D Input
* DTV/HDTV Compatibility
* 3X speed, 4-segment Enhanced White Color Wheel
Technical Details
* Brightness: 2300 ANSI Lumens; 1840 ANSI Lumens in Eco + Quiet mode
* Native Resolution: XGA (1024 x 768)
* Contrast: 2200:1
* Resizing: SXGA+ (1400 x 1050) with Intelligent ImageACE resizing
* TV Lines: 600 TV Lines (DTV 720P input)
* Device Type/Screen Size (Min/Max): Single 0.55" DDR DLP technology 12-degrees with 3x speed, 4-segment color wheel/40" (diagonal) up to 300" (diagonal)
* Cabinet Color: Titanium
* H and V Frequency/Dot Clock: fH 15-70 kHz/fV 45-85 Hz/12-108 MHz
* Compatibility/LAN Connectivity: PC, Mac, Workstation/Utilize optional AN-LS1 Ethernet to RS-232C interface
* Video System/DTV - HDTV: NTSC 3.58, 4.43/PAL, 60, M, N/SECAM/Compatibility including 1080I, 1035I, 720P, 576P, 540P, 480P, 480I
* Lens Type: 1:1.15X manual zoom and focus; F2.5-2.6, f = 19.0-21.9mm, throw ratio = 1.83-2.1
* Optical System/Built-in Audio System: Condenser Lens Optical System (provides higher image uniformity and contrast, without "ghosting")/2.0 Watts monaural
* IR Wireless Remote Control: Yes - with on-screen break timer, pointer and image "freeze" function. Also includes forward/back, and mouse presentation control (38 kHz IR carrier frequency)
* Lamp Module: AN-XR30LP or AN-XR30LP/1 (200 W, user replaceable)
* Estimated Lamp Life: 2000 hours (standard mode); 3000 hours (low-power Eco + Quiet mode)
* Fan Noise : 32dB/29dB (standard/Eco + Quiet)
* Power Source: AC 100V-240V, 2.9A
* Power Consumption (100V): Bright lamp setting, high fan mode: 283W, Eco + Quiet lamp setting, normal fan mode: 227W, Standby Mode: 4.3W
* Heat Dissipation (100V): Bright lamp setting, high fan mode: 1060 BTU/hr, Eco + Quiet lamp setting, normal fan mode: 850 BTU/hr
* Safety Approval: UL, FCC Class B
* Operating/Storage Temperatures: 41 to 95 degrees F/-4 to 140 degrees F
* Inputs/Outputs: 1 - RGB/component input (15-pin HD); 1 - DVI-D Digital/RGB/HDCP; 1 - composite video input (RCA pin type); 1 - S-video input (4-pin DIn); 1 - PC/component stereo audio input (3.5mm mini jack); 1 - video audio input (1-pair RCA pin-type); 1 - RGB loop-through output (15-pin HD); 1 - stereo "VAO" variable audio line output (3.5mm mini jack); 1 - RS-232C (9-pin mini DIN); USB (Type B)
* Optional Accessories: AN-XRCM30: Ceiling Mounting Bracket; AN-EP101B: Extension Tube for Ceiling Mount; AN-JT200: Angle-Mount joint for Ceiling Mount; AN-CMCSS16: 16" security cable system for use with ceiling mount; AN-CMCSS46: 46" security cable system for use with ceiling mount and extension tube; AN-C3CP2: Component Video cable (3-RCA to 15-pin D-sub, 10'); AN-A1RS: RS-232C adapter; AN-MR2: Remote IR Receiver (for forward/reverse presentation control); AN-C600WCC: hard-shell wheeled storage case; AN-C500SB: light duty storage case; AN-C600SC: "ATA" storage case
* Width: 10.6 inches
* Height: 4.1 inches
* Depth: 10.6 inches
* Weight: 6.4 pounds
* Warranty: 1 year parts and labor, 90 day warranty on user-replaceable projection lamp
* In the box: XR-30X, wireless remote control, two AA batteries, 6-foot AC power cord, 10-foot RGB signal cable, attached lens cap, operation manual, and CD-ROM manual
Byrjunarboð: 60þús
Sími; 8687772
