Get ekki spilað CoD í mitac fartölvu.
Snorrmund
Póstar: 1802
Skráði sig: Lau 04. Jan 2003 22:10
Póstur af Snorrmund »
Ég er með mitac fartölvu sem er með 1.8ghz intel pentium 4 og 192mb af minni :? og það er SiS 650 kubbasett í henni. Í hvert skipti sem ég keyri Call of Duty þá kemur bara þetta
COD 1.0 build win-x86 Oct  5 2003
----- FS_Startup -----
Current language: english
Current search path:
C:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
C:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
C:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
C:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
C:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files)
C:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
C:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files)
C:\PROGRA~1\CALLOF~1/main
C:\PROGRA~1\CALLOF~1\main\localized_english_pak1.pk3 (3736 files)
    localized assets pak file for english
C:\PROGRA~1\CALLOF~1\main\localized_english_pak0.pk3 (1204 files)
File Handles:
29625 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec config.cfg
couldn't exec autoexec.cfg
execing safemode.cfg
fs_basepath is write protected.
fs_homepath is write protected.
========= autoconfigure
configure.csv: using configuration 1200 cpu MHz 192 sys MB 64 vid MB
execing configure.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Measured CPU speed is 1.79 GHz
System memory is 192 MB (capped at 1 GB)
Video card memory is 64 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...37 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...37 PFDs found
...hardware acceleration found
...PIXELFORMAT 2 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
GL_VENDOR: SiS
GL_RENDERER: Compatible VGA / MMX
GL_VERSION: 2.06a.00
GL_EXTENSIONS: GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_packed_pixels GL_EXT_polygon_offset GL_EXT_separate_specular_color GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_object GL_EXT_vertex_array GL_WIN_swap_hint GL_ARB_multitexture GL_SGIS_multitexture
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Your video card appears to be missing one or more features required to run Call of Duty.
You should install the latest drivers for your video card, being sure to uninstall the old drivers first.  If you already have the latest drivers, you should completely uninstall the drivers and then reinstall them.  This fixes most problems.  If the game still doesn't work, it may be that your video card does not have the minimum features required.  Please check the readme for more information, including a list of supported video cards.
Svo ég fór á http://www.sis.com downloadaði driverana fyrir skjákortið (v2.22 nýjustu) restartaði tölvunni í safe mode henti út gömlu driverunum og setti inn nýju eins og sagt var. En þetta virkar alls ekki þetta kemur bara aftur og aftur. Einhver hér sem kannast við þetta og veit um patch/driver/fix til að laga þetta :?
Btw. Ég fór í leitina á sis.com og skrifaði Call of duty þá kom upp að þetta hefði verið lagað í útgáfu v2.21 af drivernum. Svo ég prófaði að henda drivernum út og setja hann inn en það virkar heldur ekki. .... :?
Með fyrirfram þökk.
Pandemic
Póstar: 3737
Póstur af Pandemic »
ehhh sko video driverarnir
Snorrmund
Póstar: 1802
ég var að pæla.. Er einhver síða með Cod pötchin hostuð? kannski þau lagi þetta.
Snorrmund
Póstar: 1802
Ahh var að lesa erlend forum og fann þetta... Þetta er örugglega útaf því að kortið styður ekki T&L... Á að vera hægt að laga þetta með T&L emulator eða einhverju.
