[SOLD] Intel Solid State Disk X25 Mainstream G2 80GB
FuriousJoe
Póstar: 1623
Póstur af FuriousJoe »
Er með til sölu tæp mánaðargamlann Intel SSD X25-Mainstream G2 80GB.
Diskur er í ábyrgð og lítið sem ekkert notaður.
Búið er að uppfæra í nýjasta firmware.
Mynd: http://skattertech.com/media/2009/12/wo ... 5mg2-2.jpg" onclick="window.open(this.href);return false;
Þetta er græjan sem er efst á þessum lista: http://www.harddrivebenchmark.net/common_drives.html" onclick="window.open(this.href);return false;
Tilboð Óskast !
Model Name
•Intel® X18-M Mainstream SATA Solid-State Drive
•Intel® X25-M Mainstream SATA Solid-State Drive
Capacity 80GB and 160GB
NAND flash components
•10 Parallel Channel Architecture with 34nm MLC ONFI 1.0 NAND (34nm)
•10 Parallel Channel Architecture with 50nm MLC ONFI 1.0 NAND (50nm)
Bandwidth
•Sustained Sequential Read: up to 250MB/s
•Sustained Sequential Write:
◦up to 70MB/s
Read latency
•65 microseconds (34nm)
•85 microseconds (50nm)
Write latency
•85 microseconds (34nm)
•115 microseconds (50nm)
Random I/O Operations per Second (IOPS)¹
•Random 4KB Reads: up to 35,000 IOPS (34nm and 50nm)
•Random 4KB Writes: 80GB X25/X18-M: up to 6,600 IOPS (34nm): up to 3,300 IOPS (50nm)
•Random 4KB Writes: 160GB X25/X18-M: up to 8,600 IOPS (34nm): up to 3,300 IOPS (50nm)
Interface SATA 1.5 Gb/s and 3.0 Gb/s
Form factor, height and weight
•X25-M: 2.5" Industry Standard Hard Drive Form Factor
◦7mm - 76 grams +/- 2 grams
◦9.5mm - 80 grams +/- 2 grams
Life expectancy 1.2 million hours Mean Time Before Failure (MTBF)
Power consumption
•Active: 150mW Typical (PC workload²)
•Idle (DIPM): 75mW Typical (34nm)
•Idle (DIPM): 60mW Typical (50nm)
Operating shock
•1,500G / 0.5ms (34nm)
•1,000G / 0.5ms (50nm)
Operating temperature 0°C to +70°C
Compatibility and compliance SATA Revision 2.6 Compliant. Compatible with SATA 3.0 Gb/s with Native Command Queuing and SATA 1.5 Gb/s interface rates
This product has been certified compliant by the following organizations:
RoHS compliance Meets the requirements of EU RoHS Compliance Directives
(50nm and 34 nm) and the Halogen Free Compliance Directives (34nm)
Product health monitoring Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.) commands plus additional Intel® Solid State monitoring
Frost
Póstar: 3105
Re: [TS] Intel Solid State Disk X25 Mainstream G2 80GB
Póstur af Frost »
Hvar er hann keyptur og áttu nótu?
Tölva, 2 skjáir, Varmilo lyklaborð, þráðlaus mús og næs heyrnatól
FuriousJoe
Póstar: 1623
Tölvutek, og já !
AntiTrust
Póstar: 6292
Póstur af AntiTrust »
Verðhugmynd?
Skipti? Ef svo, á hverju helst?
Σ = 29Ghz, 96GB DDR, 54TB.
yobaby
Póstar: 246
Skráði sig: Mán 28. Des 2009 09:20
Póstur af yobaby »
þú átt PM (einkaskilaboð)
Kobbmeister
Póstar: 659
Póstur af Kobbmeister »
Fylgir nokkuð 2.5" í 3.5" bracket?
Starfsmaður @ Tölvutek
FuriousJoe
Póstar: 1623
Kobbmeister skrifaði:Fylgir nokkuð 2.5" í 3.5" bracket?
Get alveg reddað því ef þú býður í þetta af viti.
Kobbmeister
Póstar: 659
Maini skrifaði:
ok.
Byrja að bjóða 35.000. Ertu á höfuðborgasvæðinu?
FuriousJoe
Póstar: 1623
Er fyrir norðan, en get sent myndir af öllu sásamt ábyrgðarnótu. Get sent búnað með flugi séi þess óskað. (viðtakandi greiðir kostnað)
Maini skrifaði:
ok.
Kobbmeister
Póstar: 659
Maini skrifaði:Er fyrir norðan, en get sent myndir af öllu sásamt ábyrgðarnótu. Get sent búnað með flugi séi þess óskað. (viðtakandi greiðir kostnað)
Geturu sent mér myndir?
annars þá er ég tilbúinn að kaupa þetta.
FuriousJoe
Póstar: 1623
Já ekkert mál, á hvaða netfang á ég að senda myndir ?
Kobbmeister
Póstar: 659
Maini skrifaði:Já ekkert mál, á hvaða netfang á ég að senda myndir ?
kobbmeister@gmail.com
FuriousJoe
Póstar: 1623
Búinn að senda þér myndir
yobaby
Póstar: 246
Póstur af yobaby »
átt pm
