Þetta kort er ca 2-3 mán og var keypti att.is
MSI Radeon HD 4890 1 GB OC Specifications
Fabrication Process: 55nm
Core Clock: 880MHz
Shader Clock: 880MHz
Stream Processors: 800 units
ROP Units: 16
Texture Filtering Units: 40
Memory Interface: 256-bit
Memory Amount/Type: 1GB/GDDR5 Memory
Memory Clock: 1000MHz (3996MHz effective)
Memory Bandwidth: 127.9 GB/s
DirectX Compliance: 10.1
Connection: 16x PCI Express 2.0
Form Factor: Dual Slot
Multi-GPU Support: Corssfire X
kemur í orginal kassa með nótu..
verð 30.000 kr
Áhugasamir geta sent mér Pm eða póst á jafo@simnet.is
Til Sölu MSI Radeon HD 4890 OC (1GB) ---SELT--
THE CLOWN
