Ég ætla að selja móðurborðið, örrann og minnið úr tölvunni minni ef ég fæ sæmilegt verð fyrir
móðurborð: GA-EP45T-UD3LR
CPU
Support for an Intel Core™ 2 Extreme processor/ Intel Core™ 2 Quad processor/Intel Core™ 2 Duo processor/Intel Pentium Dual-Core processor/Intel Celeron processor in the LGA 775 package
(Refer to CPU support list for more information)
L2 cache varies with CPU
Front Side Bus
1600/1333/1066/800 MHz FSB
Chipset
North Bridge: Intel P45 Express Chipset
South Bridge: Intel ICH10R
Memory
4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
Dual channel memory architecture
Support for DDR3 2200+/1333/1066/800 MHz memory modules
* Refer to Memory Support List for more information.
Audio
Realtek ALC888 codec
High Definition Audio
2/4/5.1/7.1-channel
Support for S/PDIF In/Out
Support for CD In
LAN
1 x Realtek 8111C chips (10/100/1000 Mbit)
Expansion Slots
1 x PCI Express x16 slot, running at x16 (The PCI Express x16 slot conforms to PCI Express 2.0 standard)
4 x PCI Express x1 slot
2 x PCI slots
Storage Interface
South Bridge:
6x SATA 3Gb/s connectors (SATA2_0, SATA2_1, SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 6 SATA 3Gb/s devices
Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
GIGABYTE SATA2 (JMicron 368) chip:
1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
iTE IT8718 chip:
1 x floppy disk drive connector supporting up to 1 floppy disk drive
USB
Integrated in the South Bridge
Up to 12 USB 2.0/1.1 ports (8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors
1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x IDE connector
6 x SATA 3Gb/s connectors
1 x CPU fan header
2 x system fan headers
1 x power fan header
1 x front panel header
1 x front panel audio header
1 x CD In connector
1 x S/PDIF In header
1 x S/PDIF Out header
2 x USB 2.0/1.1 headers
1 x parallel port header
1 x serial port header
1 x power LED header
1 x chassis intrusion header
Back Panel Connectors
1 x PS/2 mouse port
1 x PS/2 keyboard/mouse port
1 x optical S/PDIF Out connector
1 x coaxial S/PDIF Out connector
8 x USB 2.0/1.1 ports
1 x RJ-45 ports
6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line
I/O Controller
iTE IT8718 chip
H/W Monitoring
System voltage detection
CPU/System temperature detection
CPU/System/Power fan speed detection
CPU overheating warning
CPU/System/Power fan fail warning
CPU/System fan speed control
BIOS
2 x 8 Mbit flash
Use of licensed AWARD BIOS
Support for Dual BIOS
PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Download Center
Support for Xpress Install
Support for Xpress Recovery2
Support for EasyTune 6
Support for Dynamic Energy Saver Advanced
Support for Time Repair
Support for Q-Share
Support for Ultra TPM
Örri: Intel E8400 (þið þekkið þennan allir geri ég ráð fyrir)
Kæling: OCZ Vindicator
Minni: OCZ DDR3 PC3-16000 / 2000MHz / EPP 2.0 Ready / Platinum Edition
EPP 9-9-9-30
(CAS-TRCD-TRP-TRAS)
Available in 1GB and 2GB modules and optimized kits
Unbuffered
Platinum Z3 XTC Heatspreader
Lifetime Warranty
1.8 Volts
240 Pin DIMM
Special Features
EPP 2.0-Ready**
1.85V EVP***
Þetta er allt samsett og tilbúið. Ég er að keyra þetta á 3.6GHz CPU og 1600MHz RAM en það er hægt að keyra minnið hraðar ef maður er með örgjörva sem keyrir á hærri FSB. Skemmtilegt dót fyrir yfirklukkara en ég get selt þetta allt saman eins og það er og á núverandi klukkum og maður þarf ekkert að kunna á yfirklukkun til að keyra þetta stabílt. Hendi inn búðarverðum á þessu innan skamms til samanburðar.
EDIT: Búðarverð eru:
E8400: 27.900 á computer.is
móðurborð: 24.900 á tolvutek.is
Minni: Finn ekki þetta minni í íslenskum verslunum en Mushkin 4GB DDR3 1600MHz CL8 kostar 29.900 á tolvutek.is þannig að ég er bara fair og set 15.000 á mitt.
