19" widescreen Samsung 2ms
albertgu
Póstar: 82
Skráði sig: Sun 30. Sep 2007 21:47
Póstur af albertgu »
Monitor Type: Flat Panel LCD TFT (Active Matrix)
Contrast Ratio: 2,000:1
Aspect Ratio: 16:10
Brightness: 300 cd/m²
Response Time: 2 ms
Dot Pitch: 0.285 mm
Color Depth: 24-bit (16.7M Colors)
Viewable Picture Size: 19 in.
Digital Video Input Standard: DVI-D
orm Factor: Desktop
Resolutions supported: 1440 x 900
Synchronization Range - Vertical : 56 - 75 Hz
Synchronization Range - Horizontal : 30 - 81 kHz
Max. Viewing Angle - Horizontal : 160
Max. Viewing Angle - Vertical : 160
Native (Recommended) Resolution: 1440 x 900
"CNET Product brief"
Description: The Samsung SyncMaster 906BW is a 19 in, flat panel computer monitor.Compared to other flat panel monitors on the market, it is relatively inexpensive at around $260.This unit features a 1440x900 native resolution.Weighs 9.3 lbs.
Pros: Has 16:10 aspect ratio, which is more favorable than some similarly priced monitors.By way of comparison, the average cost of a product with this favorable an aspect ratio is $470.Its wide viewing angle (160 degrees) is useful whenever the screen is being viewed by more than one person at the same time.Accepts DVI input, which allows for greater signal clarity than traditional VGA.
Cons: None noted, given available product data.
Suitability: A flat panel monitor, suited for those who want a spacious thin screen monitor.The 2 ms response time of this screen makes it ideal for fast-moving games and for watching movies.
Value: In view of its relatively inexpensive price, this monitor has great features for the money.For example, when it comes to viewable screen size, the average price of flat panel monitors with similar viewable size is quite a bit more -- in fact around $320.
Heimildir: http://reviews.cnet.com/lcd-monitors/sa" onclick="window.open(this.href);return false; ... 27972.html
http://www.epinions.com/specs/Samsung_906BW_Monitor" onclick="window.open(this.href);return false;
Intel Q6600 @ 2.40 ~ MSI P6N Nforce 680i ~ 2x 150 GB Raptor + 500GB ~ 2x 1GB Corsair XMS Dominator 1066MHz ~ 8800GTS 512MB ~ SB XFI Xtreme ~ 700W Fotron
albertgu
Póstar: 82
Re: 19" widescreen Samsung 2ms
bjóðið bara í þetta kvikindi, hefur reynst mér frábærlega en mér vantar bara pening
freyzi11
Póstar: 32
Skráði sig: Mán 12. Jan 2009 01:51
Póstur af freyzi11 »
Vá þetta er geðveikur skjÁR Býð 22 þús í þetta geðveika kvikyndi
intenz
Póstar: 3337
Staðsetning: /dev/null
Póstur af intenz »
Býð 15.000 kr.
thorstt@husa.is
Beetle
Póstar: 214
Skráði sig: Mið 16. Ágú 2006 17:52
Staðsetning: 104 Rvík.
Póstur af Beetle »
Ok skal borga þér 10.000.- stgr. vantar skjá f. pabba míns.
Nariur
Póstar: 1574
Póstur af Nariur »
venjulega býður maður hærra en fólkið á undan manni.
freyzi11
Póstar: 32
já ég dreg boð mitt til baka en mér finnst lámark 20k i kvikindi
suddalegur i leiki og horfa á myndir átti svona :D
albertgu
Póstar: 82
TTT ennþá til sölu, hæsta boð er sem stendur 18000
freyzi11
Póstar: 32
18 þus er ekki neitt fyrir þennan skja ef ég bara ætti pening, mæli með þessum
alexone
Póstar: 107
Skráði sig: Fim 31. Júl 2008 23:55
Staðsetning: Reykjanesbær/Grindavik
Póstur af alexone »
skoðaðu pm
Revolution
Póstar: 17
Skráði sig: Fim 31. Des 2009 03:48
Póstur af Revolution »
seldur?
KIDDI109
Póstar: 18
Skráði sig: Mán 04. Jan 2010 03:19
Póstur af KIDDI109 »
til í skipti?
alexone
Póstar: 107
Póstur af alexone »
Seldur?
