BFG Nvidia Geforce 8800 320MB GTS OC
stebbi23
Póstar: 156
Skráði sig: Fös 17. Júl 2009 09:59
Póstur af stebbi23 »
Er með 1. stk notað BFG Nvidia Geforce 8800 320MB GTS OC sem er í fínasta standi.
BFG NVIDIA GeForce 8800 GTS OC 320MB PCIe
Performance
GPU NVIDIA GeForce 8800 GTS
Core Clock 550MHz (vs. 500MHz standard)
Shader Clock 1300MHz (vs. 1200MHz standard)
Texture Fill Rate 26.4 billion/sec.
Stream Processors 96
MemoryVideo
Memory 320MB
Memory Type GDDR3
Memory Data Rate 1600MHz
Memory Bandwidth 64GB/sec.
ConnectionsBus Type
PCI Express x16
Connector(s) 2 Dual-Link DVI-I, HDTV + TV Out
RAMDACs Dual 400MHz
Multiple Monitor Support Yes
HDCP Capable Yes (Requires other compatible components which are HDCP capable. Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc and HD DVD formats, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays)
Minimum System Requirements
1GB of system memory
Microsoft Windows Vista -or- Windows XP
CD or DVD-ROM drive
50MB of available hard disk drive space for basic driver installation
A 425W PCI Express-compliant system power supply with a combined 12V current rating of 28A or more *Minimum system power requirement based on a typical PC configured with an Intel® Core™2 Extreme X6800 processor
A PCI Express-compliant motherboard with an available PCI Express x16 slot. A vacant slot below the PCI Express x16 slot. The graphics card physically occupies two slots
One 6-pin PCI Express supplementary power connector -or- Two 4-pin Molex power connectors
NVIDIA SLI Requirements: Combine multiple BFG NVIDIA GeForce-based graphics cards with an NVIDIA nForce® SLI-based motherboard. IMPORTANT: Graphics cards MUST be from the same manufacturer and contain identical GPUs. For example, a BFG NVIDIA GeForce 8800 GTS PCIe can only be paired with another BFG NVIDIA GeForce 8800 GTS PCIe graphics card
http://www.bfgtech.com/bfgr88320gtsoce.aspx" onclick="window.open(this.href);return false;
http://www.pcper.com/article.php?aid=36 ... ert&pid=11" onclick="window.open(this.href);return false;
Verð: Hæsta boð, tilboð
Hafa samband: PM á spjallinu
di0zwhat?
Póstar: 72
Skráði sig: Mið 09. Sep 2009 22:03
Re: BFG Nvidia Geforce 8800 320MB GTS OC
Póstur af di0zwhat? »
ég býð 5k
sittinghorse
Póstar: 11
Skráði sig: Fim 06. Ágú 2009 23:13
Póstur af sittinghorse »
6000
rottuhydingur
Póstar: 191
Skráði sig: Mið 01. Júl 2009 18:41
Póstur af rottuhydingur »
6500 ? sendu a mig pm
AronBjörns
Póstar: 261
Skráði sig: Fim 22. Okt 2009 16:14
Póstur af AronBjörns »
7.500 kr 856-8924 get tekið þetta í dag
