Vista SP1 changelog
Vista SP1 changelog
Fumbler
- Póstar: 484
- Skráði sig: Mið 23. Apr 2003 17:15
- Staðsetning: Vestfirðir
Ég var mjög feginn að sjá þetta í listanum. Er farið að vera svoldið pirrandi.
# Improves performance over Windows Vista’s current performance across the following scenarios:
* 25% faster when copying files locally on the same disk on the same machine
* 45% faster when copying files from a remote non-Windows Vista system to a SP1 system
* 50% faster when copying files from a remote SP1 system to a local SP1 system
Pandemic
- Póstar: 3737
- Skráði sig: Fim 31. Júl 2003 15:25
Verð að segja nokkra nice hluti hérna
Marg á þessum lista sem á eftir að setja Vista á mun hærra plan en það hefur verið á.
Improves power consumption and battery life by addressing an issue that causes a hard disk to continue spinning when it should spin down, in certain circumstances.
Improves power consumption when the display is not changing by allowing the processor to remain in its sleep state which consumes less energy.
Improves the time to read large images by approximately 50%.
Adds support for exFAT, a new file system supporting larger overall capacity and larger files, which will be used in Flash memory storage and consumer devices.
