Nýliðið á skjákorta markaðnum =)
gnarr
Póstar: 6208
Póstur af gnarr »
http://www.xgitech.com/
XGI :D þessi kort lofa góðu. nú er bara að sjá hvernig þeir standa sig í Doom 3, HL2 stríðinu í vetur. Vonandi er loksins komið nýtt fyrirtæki til að sparka í rassgatið á nVidia og Ati.
gnarr
Póstar: 6208
Póstur af gnarr »
Volari™ Duo V8 Ultra Specifications
Blazing-fast PCI Bus Interface
- 32-bit PCI local bus standard Revision 2.2 compliant
- True AGP2.0 & AGP3.0 Compliant configuration setting
- Hardware auto detect for AGP1.0, AGP2.0 or AGP3.0 mode support
Double Octa-pipe 3D Engine
- Extreme High performance 256-bit 3D engine
- High order surface tessellation
- Optimized hardware geometry transform/lighting/setup engine
- Total of 4 units of Vertex Shader with Fully compliant Direct3D 9.0 Vertex Shader ver. 2.0
- Total of 8 sets of Pixel Shader (2.0) with Fully compliant Direct3D 9.0 Pixel Shader ver. 2.0
- 16 sets high performance pixel rendering pipelines
- Supports Bump Mapping, Mipmapped Cubic Mapping and Volume Texture supports flat and Gouraud shading
- High quality anisotropic filtering
- Supports 2-side stencil.
- 2X/4X full scene anti-aliasing(FSAA)
Ultimate Performance 2D Engine
- Hardware command queue
- High-speed Direct Draw Accelerator
- Hardware GDI 2000 Accelerator
- Source read-buffer to minimize engine wait-state
- Built-in destination read-buffer to minimize engine wait-state
High Definition TV-OUT Solution with XV301
- PAL and NTSC Systems.
- Composite, S-Video, and Component RGB Output Signals
- Macrovision Copy Protection Process Rev. 7.1.L1
- HDTV 480i/480p/1080i/720p YPbPr Output Signals.
- A single link TMDS transmitter with excellent scaling capability for TFT LCD panel display
MPEG-2 Video Decoder
- MPEG-2 MP@ML standards compliant
- Supports up to 20 Mbit/sec bit rate decoding
- True hardware VCD, DVD and HDTV decoding
Video Accelerator
- YUV-to-RGB color space conversion
- Bi-linear video interpolation with integer increments of 1/2048
- Complete graphics and video overlay function
- Hardware video decoder interface
- Independent VBI capture
- Supports DVD sub-picture playback overlay
- Built-in independent Gamma correction RAM
Proprietary Cipher Video Processor
- 5 fields per-pixel motion detection de-interlace function, video sources from MPEG decoder, Video capture and AVI interfaces.
- Down scaling function and scaling vector as 1/2, 1/4.
- Next generation de-interlaced and 1/2 down scaling function.
Display Memory Interface
- Supports DDR SDRAM, DDR-II SDRAM type to 256M Bytes memory
BitFluent Architecture (XGI Volari Duo Only)
- Advanced interface for dual GPU solution
- Up to 2.13GB bus bandwidth
High Integration
- Programmable 24-bit true-color RAMDAC up to 400 MHz pixel clock
- Built-in VIP interface
- VESA Plug & Display for PanelLink Interface
- Built-in Thermal Diode for GPU Security-Update
Miscellaneous
- Supports 32K/64K/128K Bytes ROM decoding
- Supports 20MHz SPI ROM interface 1140-balls 37.5mm x 37.5mm FC-BGA package
elv
Póstar: 1949
Skráði sig: Sun 23. Mar 2003 21:53
Póstur af elv »
Hljómar ágætlega en ég þar að gefa upp of mikið af upplýsingum um mig bara til að fá að vita hvar ég gæti keypt þetta!!!!!!! :evil:
gnarr
Póstar: 6208
Póstur af gnarr »
þetta verður sjálfsagt komið í retail eftir 2 mánuði
