Kann einhver að yfirklukka þennan skratta. Í BIOS eru stillingarnar greyed out. Og ég er ekki með neitt floppy drif til að flasha nýju BIOS.
Móðurborð:
Motherboard Properties
Motherboard ID 06/06/2005-KM400A-8237-6A6LYA0E-00
Motherboard Name Asus A7V8X-LA (Kelut)
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Bandwidth 3200 MB/s
Chipset Bus Properties
Bus Type VIA V-Link
Bus Width 8-bit
Real Clock 67 MHz (ODR)
Effective Clock 533 MHz
Bandwidth 533 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1 Socket 462
Expansion Slots 3 PCI, 1 AGP
RAM Slots 2 DDR DIMM
Integrated Devices Audio, Video, LAN, IEEE-1394
Form Factor Micro ATX
Motherboard Size 240 mm x 240 mm
Motherboard Chipset KM400A
Motherboard Manufacturer
Company Name ASUSTeK Computer Inc.
Product Information http://www.asus.com/products1.aspx?l1=3
BIOS Download http://support.asus.com/download/downlo ... uage=en-us
CPU:
CPU Properties
CPU Type AMD Athlon XP, 2100 MHz (10.5 x 200) 3000+
CPU Alias Barton
CPU Stepping A2
Instruction Set x86, MMX, 3DNow!, SSE
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 512 KB (On-Die, Full-Speed)
CPU Physical Info
Package Type 453 Pin PGA
Package Size 4.95 cm x 4.95 cm
Transistors 54.3 million
Process Technology 6Mi, 0.13 um, CMOS, Cu
Die Size 101 mm2
Core Voltage 1.65 V
I/O Voltage 1.6 V
Typical Power 53.7 - 60.4 W (depending on clock speed)
Maximum Power 68.3 - 76.8 W (depending on clock speed)
CPU Manufacturer
Company Name Advanced Micro Devices, Inc.
Product Information http://www.amd.com/us-en/Processors/Pro ... 18,00.html
CPU Utilization
CPU #1 0 %
BIOS:
BIOS Properties
BIOS Type Award
Award BIOS Type Phoenix - Award BIOS v6.00PG
Award BIOS Message Copyright 2005 by Hewlett-Packard Company Rev.3.15
System BIOS Date 06/06/05
Video BIOS Date 07/08/03
BIOS Manufacturer
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index ... fererid=40
Problems & Suggestions
Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today!
Suggestion Video BIOS is more than 2 years old. Update it if necessary.
AMD overclock
No Neck Linda
Höfundur - Nýliði
- Póstar: 10
- Skráði sig: Þri 21. Jún 2005 09:46
No Neck Linda
Höfundur - Nýliði
- Póstar: 10
No Neck Linda
Höfundur - Nýliði
- Póstar: 10
No Neck Linda
Höfundur - Nýliði
- Póstar: 10
