Hvort er betra?
marino_i
Póstar: 22
Skráði sig: Mán 02. Jan 2006 23:13
Staðsetning: RVK
Hvort er betra?
Póstur af marino_i »
*******Hvort er betra?*******
Móðurborð - AMD - Socket 939 - Abit UL8 AGP8x 10/100 ULI Mt1689
Kr. 8.570
Staðgreitt
Kr. 8.313
Magn
AGP Slots: 1x AGP 4X/8X
CPU Type: Athlon 64 FX/Athlon 64/Sempron
DDR Standard: DDR 400 (PC 3200)
Dual Channel Supported: Yes
FSB: 1000MHz Hyper Transport (2000 MT/s)
Maximum Memory Supported: 8GB
Number of DDR Slots: 4x 184pin DDR
P ATA: 2 x ATA100 up to 4 Devices
PCI Slots: 5
SATA I: 2
CPU
Designed for AMD Socket 939 Athlon64/ Athlon64 FX processors with 2000MT/s system bus using Hyper Transport™ Technology
Support AMD next generation Dual Core CPU
Support AMD CPU Cool 'n' Quiet Technology
Chipset
ULI M1689 single chip
Memory
Four 184 -pin DIMM sockets
Supports Dual DDR400 Un-buffered ECC/Non-ECC memory
Supports maximum memory capacity up to 8GB
Graphic
AGP8X
SATA RAID
Supports SATA 1.5Gbps data transfer rate
SATA RAID 0/1
LAN
On board 10/100 Mb LAN
Audio
On board 5.1 channels Audio CODEC
Supports auto jack sensing and optical S/PDIF Out
ABIT Engineered
ABIT SoftMenu™ Technology
ABIT CPU ThermalGuard™ Technology
Internal I/O Connectors
1 x AGP 8X, 5 x PCI slot
1 x Floppy Port supports up to 2.88MB
2 x Ultra DMA 133/100/66/33 IDE Connectors
2 x SATA Connectors
2 x USB 2.0 headers; 1 x CD-IN header
Back Panel I/O
1 x PS/2 Keyboard, 1 x PS/2 Mouse
1 x Serial Port connector, 1 x Parallel Port connector, 1 x S/PDIF Out Connector
1 x Audio connector (Line Out, Line-in, MIC-in)
4 x USB Connectors, 1 x RJ-45 LAN Connector
eða
ABIT AN8 Fatal1ty SLI
AMD Athlon 64 socket 939
NForce 4 SLI
PCI Express, PCI
Overall Score: 96 points
The full specification (taken from ABIT's website)
CPU
Supports AMD Socket 939 Athlon 64/64FX & Athlon 64 X2 dual-core Processors
With 2GHz system bus using Hyper Transport™ technology
Supports AMD CPU Cool 'n' Quiet Technology
Chipset
NVIDIA NF4 SLI single chip
NVIDIA Gigabit Ethernet with NVIDIA Firewall
Supports NV SATA 3G RAID
NVIDIA SLI Technology
Two PCI-Express X16 slots support NVIDIA Scalable Link Interface
Increase bandwidth of the PCI Express™ bus providing 60x the bandwidth of PCI
Memory
Four 184-pin DIMM sockets
Supports dual channel DDR400 non-ECC un-buffered memory
Supports maximum memory capacity up to 4GB
ABIT Engineered
ABIT µGuru™ 2003 Technology
ABIT OTES™ Technology
ABIT AudioMAX™ Technology
NV SATA RAID
Serial ATA 3Gbps data transfer rate
Supports SATA RAID 0/1/0+1
NV GbE LAN
NVIDIA Secure Networking Engine
NV Firewall
Native NVIDIA Firewall
IEEE1394
Support IEEE 1394 at 400 Mb/s transfer rate
ABIT AudioMAX
High quality 7.1-channel Audio Card
Optical S/P DIF Input/Output
2 x PCI Express X16, 2 x PCI Express X1, 2 x PCI slots, 1 x AudioMAX
Floppy Port supports up to 2.88 MB
4 x SATA 3G Connectors
3 x USB headers, 1 x IEEE 1394 header
Back Panel I/O
ABIT Dual OTES
1 x PS/2 Keyboard, 1 x PS/2 mouse
1 x IEEE 1394
4 x USB, 1 x RJ-45 LAN Connector
Form Factor
ATX form factor 305 x 245mm
Accessories
OTES SLIpstream
Guru Panel
ABIT AudioMAX Card
SLI Connector Bridge
SLI Switch
SATA cable x 4, ATA 100 IDE Cable x 1, FDD cable x 1
I/O shield x 1
CD Title x 1, SATA Utility Disk x 1
A5 standard User's Manual x 1, B5 multilingual Quick Installation Guide x 1
Jumper Setting Label
Verð:18,000
Endilega svariði :D
ponzer
Póstar: 1268
Skráði sig: Þri 07. Sep 2004 18:18
Staðsetning: Router(config)#
Póstur af ponzer »
Frekar ólík borð, annað með AGP rauf og hitt PCI-e rauf...
Annars er ég svolítið hrifinn af Fatal1ty borðinu.
mjamja
Póstar: 301
Skráði sig: Mán 26. Des 2005 20:38
Póstur af mjamja »
ég myndi segja að Fatal1ty sé betra borð
@Arinn@
Póstar: 1277
Staðsetning: Kópavogur
Póstur af @Arinn@ »
Eru Abit ekki búnir að vera að koma með frekar slöpp borð uppá síðkastið ?
DoRi-
Póstar: 1023
Skráði sig: Mið 20. Okt 2004 19:18
Staðsetning: 127.0.0.1
Póstur af DoRi- »
@Arinn@ skrifaði:Eru Abit ekki búnir að vera að koma með frekar slöpp borð uppá síðkastið ?
fatal1ty borðið er búið að vera frekar lengi
ég er ekki búinn að sjá neitt slæmt um það ennþá
Vilezhout
Póstar: 401
Skráði sig: Þri 04. Nóv 2003 02:30
Staðsetning: Nethimnaríki
Póstur af Vilezhout »
u-guru er auðvitað hreinasta snilld
This monkey's gone to heaven
gumball3000
Póstar: 92
Skráði sig: Mán 26. Des 2005 23:06
Póstur af gumball3000 »
ég er með fatality ekki sli týpuna og það er rusl :? búinn að standa í alskonar bluescreen veseni og rugli með það :cry: mér kvíður alltaf fyrir að að formatta etta er svo mikið rusl :P
3500+ Retail - Abit AN8 AMD Athlon Fatality - DDR 2048Mb Dual Channel (400) - Geforce 6600 GT - 3x 400gb seagate 3x 250gb wd 2x 200gb seagate 1x 120gb wd
Vilezhout
Póstar: 401
gumball3000 skrifaði:ég er með fatality ekki sli týpuna og það er rusl :? búinn að standa í alskonar bluescreen veseni og rugli með það :cry: mér kvíður alltaf fyrir að að formatta etta er svo mikið rusl :P
ég hef verið að sjá helling af góðri umfjöllun um þetta borð á abit spjallborðunum :roll:
Ert sennilega í einhverjum minnisvandræðum eða að móðurborðið hjá þér gæti sömuleiðis verið gallað
Yank
Póstar: 1058
Skráði sig: Mið 29. Des 2004 17:01
Staðsetning: www.tech.is
Póstur af Yank »
Abit framleiða góð móðurborð á tímabili var þetta eini framleiðandinn sem hugsaði um okkur sem OC.
zedro
Póstar: 2755
Staðsetning: Flight level 100
Póstur af zedro »
Fatal1ty borðið án efa.
Mar kaupir sér ekki AGP mobo bara bannað. :shock:
Fractal Design: Define S - Aerocool Strike-X 1100W - ASRock 990FX Extreme9 AM3+ ATX - FX-9590 Vishera w/BeQuiet Silent Loop 360mm - G.Skill 16GB (2x8GB) Sniper 1866MHz DDR3 - Sapphire Fury X - 480GB SSD OS + 2TB DATA
gumball3000
Póstar: 92
true
kristjanm
Póstar: 1196
Skráði sig: Sun 20. Jún 2004 23:07
Póstur af kristjanm »
Abit eru þekktir fyrir að vera gott og traust merki og sjálfur hef ég góða reynslu af þeim.
Held að fyrirtækið sé að fara í hundana samt...
