Gamlar 3Dmark niðurstöður
- Nörd
- Póstar: 145
- Skráði sig: Þri 22. Apr 2003 11:37
ég var að dl 3dmark 2001, en það er ekkert að virka...
það kemur alltaf
það kemur alltaf
svo annað sem ég nennti ekki að skrifa,ég er búinn að dl directX 8.1 fyrir win2k en.. þetta er ekkert að lagast3DMark2001 SE needs directx 8.1 and proper drivers installed in order to run
Install Microsoft DirectX 8.1 and try again
- Nörd
- Póstar: 145
- Nörd
- Póstar: 145
þetta er þaðApplication info
Name 3DMark2001 SE
Build 300
Error log
DirectX8 not installed.
System info available: yes
Project available: no
System info
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer Intel
Family Pentium® 4
Internal Clock 2.62 GHz
Internal Clock Maximum 2.93 GHz
External Clock 133 MHz
Socket Designation Socket-478
Type <unknown>
Upgrade <unknown>
Capabilities MMX, CMov, RDTSC, SSE, SSE2
Version Intel(R) Pentium(R) 4 Processor
CPUID 0x00000f27
CACHES
Level 1
Capacity 8 KB
Type Data, Internal
Type Details Synchronous, Pipeline Burst
Error Correction Type Single-bit ECC
Associativity 4-way Set-Associative
Level 2
Capacity 512 KB
Type Instruction, Data, Internal
Error Correction Type Parity
Associativity 8-way Set-Associative
DIRECTX INFO
DirectX Version 8.0
DIRECTDRAW INFO
DirectDraw Version 5.3.0000000.900
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer ATI Technologies Inc.
Name RADEON 9500 PRO / 9700
Total Local Video Memory 128 MB
Total Local Texture Memory 128 MB
Total AGP Memory 56 MB
Display Driver ati2dvag.dll
Display Driver Version 6.14.10.6368
Driver WHQL Certified Yes
Max Texture Width 2048
Max Texture Height 2048
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 8
Vertex Shader Version 1.1
Pixel Shader Version 1.4
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
Vendor ID 0x1002
Device ID 0x4e45
Sub-System ID 0x30021002
Revision 0x00
DISPLAY MODES
Resolution 320x200x16-bit RGB [565] @ 60 Hz
Resolution 320x200x16-bit RGB [565] @ 75 Hz
Resolution 320x200x32-bit RGB [888] @ 60 Hz
Resolution 320x200x32-bit RGB [888] @ 75 Hz
Resolution 320x240x16-bit RGB [565] @ 60 Hz
Resolution 320x240x16-bit RGB [565] @ 75 Hz
Resolution 320x240x32-bit RGB [888] @ 60 Hz
Resolution 320x240x32-bit RGB [888] @ 75 Hz
Resolution 400x300x16-bit RGB [565] @ 60 Hz
Resolution 400x300x16-bit RGB [565] @ 75 Hz
Resolution 400x300x32-bit RGB [888] @ 60 Hz
Resolution 400x300x32-bit RGB [888] @ 75 Hz
Resolution 512x384x16-bit RGB [565] @ 60 Hz
Resolution 512x384x16-bit RGB [565] @ 75 Hz
Resolution 512x384x32-bit RGB [888] @ 60 Hz
Resolution 512x384x32-bit RGB [888] @ 75 Hz
Resolution 640x400x16-bit RGB [565] @ 60 Hz
Resolution 640x400x16-bit RGB [565] @ 75 Hz
Resolution 640x400x32-bit RGB [888] @ 60 Hz
Resolution 640x400x32-bit RGB [888] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 60 Hz
Resolution 640x480x16-bit RGB [565] @ 72 Hz
Resolution 640x480x16-bit RGB [565] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 85 Hz
Resolution 640x480x16-bit RGB [565] @ 90 Hz
Resolution 640x480x16-bit RGB [565] @ 100 Hz
Resolution 640x480x16-bit RGB [565] @ 120 Hz
Resolution 640x480x32-bit RGB [888] @ 60 Hz
Resolution 640x480x32-bit RGB [888] @ 72 Hz
Resolution 640x480x32-bit RGB [888] @ 75 Hz
Resolution 640x480x32-bit RGB [888] @ 85 Hz
Resolution 640x480x32-bit RGB [888] @ 90 Hz
Resolution 640x480x32-bit RGB [888] @ 100 Hz
Resolution 640x480x32-bit RGB [888] @ 120 Hz
Resolution 800x600x16-bit RGB [565] @ 56 Hz
Resolution 800x600x16-bit RGB [565] @ 60 Hz
Resolution 800x600x16-bit RGB [565] @ 70 Hz
Resolution 800x600x16-bit RGB [565] @ 72 Hz
Resolution 800x600x16-bit RGB [565] @ 75 Hz
Resolution 800x600x16-bit RGB [565] @ 85 Hz
Resolution 800x600x16-bit RGB [565] @ 90 Hz
Resolution 800x600x16-bit RGB [565] @ 100 Hz
Resolution 800x600x16-bit RGB [565] @ 120 Hz
Resolution 800x600x32-bit RGB [888] @ 56 Hz
Resolution 800x600x32-bit RGB [888] @ 60 Hz
Resolution 800x600x32-bit RGB [888] @ 70 Hz
Resolution 800x600x32-bit RGB [888] @ 72 Hz
Resolution 800x600x32-bit RGB [888] @ 75 Hz
Resolution 800x600x32-bit RGB [888] @ 85 Hz
Resolution 800x600x32-bit RGB [888] @ 90 Hz
Resolution 800x600x32-bit RGB [888] @ 100 Hz
Resolution 800x600x32-bit RGB [888] @ 120 Hz
Resolution 1024x768x16-bit RGB [565] @ 60 Hz
Resolution 1024x768x16-bit RGB [565] @ 70 Hz
Resolution 1024x768x16-bit RGB [565] @ 72 Hz
Resolution 1024x768x16-bit RGB [565] @ 75 Hz
Resolution 1024x768x16-bit RGB [565] @ 85 Hz
Resolution 1024x768x16-bit RGB [565] @ 90 Hz
Resolution 1024x768x16-bit RGB [565] @ 100 Hz
Resolution 1024x768x32-bit RGB [888] @ 60 Hz
Resolution 1024x768x32-bit RGB [888] @ 70 Hz
Resolution 1024x768x32-bit RGB [888] @ 72 Hz
Resolution 1024x768x32-bit RGB [888] @ 75 Hz
Resolution 1024x768x32-bit RGB [888] @ 85 Hz
Resolution 1024x768x32-bit RGB [888] @ 90 Hz
Resolution 1024x768x32-bit RGB [888] @ 100 Hz
Resolution 1152x864x16-bit RGB [565] @ 60 Hz
Resolution 1152x864x16-bit RGB [565] @ 70 Hz
Resolution 1152x864x16-bit RGB [565] @ 75 Hz
Resolution 1152x864x16-bit RGB [565] @ 85 Hz
Resolution 1152x864x32-bit RGB [888] @ 60 Hz
Resolution 1152x864x32-bit RGB [888] @ 70 Hz
Resolution 1152x864x32-bit RGB [888] @ 75 Hz
Resolution 1152x864x32-bit RGB [888] @ 85 Hz
Resolution 1280x768x16-bit RGB [565] @ 56 Hz
Resolution 1280x768x16-bit RGB [565] @ 60 Hz
Resolution 1280x768x16-bit RGB [565] @ 75 Hz
Resolution 1280x768x16-bit RGB [565] @ 85 Hz
Resolution 1280x768x32-bit RGB [888] @ 56 Hz
Resolution 1280x768x32-bit RGB [888] @ 60 Hz
Resolution 1280x768x32-bit RGB [888] @ 75 Hz
Resolution 1280x768x32-bit RGB [888] @ 85 Hz
Resolution 1280x960x16-bit RGB [565] @ 60 Hz
Resolution 1280x960x16-bit RGB [565] @ 70 Hz
Resolution 1280x960x16-bit RGB [565] @ 72 Hz
Resolution 1280x960x16-bit RGB [565] @ 75 Hz
Resolution 1280x960x16-bit RGB [565] @ 85 Hz
Resolution 1280x960x32-bit RGB [888] @ 60 Hz
Resolution 1280x960x32-bit RGB [888] @ 70 Hz
Resolution 1280x960x32-bit RGB [888] @ 72 Hz
Resolution 1280x960x32-bit RGB [888] @ 75 Hz
Resolution 1280x960x32-bit RGB [888] @ 85 Hz
Resolution 1280x1024x16-bit RGB [565] @ 60 Hz
Resolution 1280x1024x16-bit RGB [565] @ 70 Hz
Resolution 1280x1024x16-bit RGB [565] @ 74 Hz
Resolution 1280x1024x16-bit RGB [565] @ 75 Hz
Resolution 1280x1024x32-bit RGB [888] @ 60 Hz
Resolution 1280x1024x32-bit RGB [888] @ 70 Hz
Resolution 1280x1024x32-bit RGB [888] @ 74 Hz
Resolution 1280x1024x32-bit RGB [888] @ 75 Hz
Resolution 1600x1200x16-bit RGB [565] @ 60 Hz
Resolution 1600x1200x16-bit RGB [565] @ 70 Hz
Resolution 1600x1200x32-bit RGB [888] @ 60 Hz
Resolution 1600x1200x32-bit RGB [888] @ 70 Hz
TEXTURE FORMATS
Pixel Format 32-bit ARGB [8888]
Pixel Format 32-bit RGB [888]
Pixel Format 16-bit RGB [565]
Pixel Format 16-bit RGB [555]
Pixel Format 16-bit ARGB [1555]
Pixel Format 16-bit ARGB [4444]
Pixel Format 8-bit A [8]
Pixel Format 8-bit YUV [800]
Pixel Format FourCC [UYVY]
Pixel Format FourCC [YUY2]
Pixel Format FourCC [DXT1]
Pixel Format FourCC [DXT2]
Pixel Format FourCC [DXT3]
Pixel Format FourCC [DXT4]
Pixel Format FourCC [DXT5]
3D Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.05.01.0900
REGISTERED DIRECTSHOW FILTERS
Filter .RAM file Parser
Filter AC3 Parser Filter
Filter ACELP.net Sipro Lab Audio Decoder
Filter ACM Wrapper
Filter ASF ACM Handler
Filter ASF DIB Handler
Filter ASF DJPEG Handler
Filter ASF ICM Handler
Filter ASF JPEG Handler
Filter ASF URL Handler
Filter ASF embedded stuff Handler
Filter ASX file Parser
Filter ASX v.2 file Parser
Filter AVI Decompressor
Filter AVI Draw
Filter AVI Splitter
Filter AVI/WAV File Source
Filter BDA MPE Filter
Filter BDA MPEG2 Transport Information Filter
Filter BDA Slip De-Framer
Filter Color Space Converter
Filter DV Muxer
Filter DV Splitter
Filter DV Video Decoder
Filter Default DirectSound Device
Filter Default MidiOut Device
Filter DivX Decoder Filter
Filter File Source (Async.)
Filter File Source (Netshow URL)
Filter File Source (URL)
Filter File stream renderer
Filter IVF source filter
Filter Indeo® audio software
Filter Indeo® video 5.10 Decompression Filter
Filter Internal Script Command Renderer
Filter Line 21 Decoder
Filter Line 21 Decoder 2
Filter Lyric Parser
Filter MIDI Parser
Filter MJPEG Decompressor
Filter MPEG Audio Decoder
Filter MPEG Layer-3 Decoder
Filter MPEG Video Decoder
Filter MPEG-2 Demultiplexer
Filter MPEG-2 Sections and Tables
Filter MPEG-2 Splitter
Filter MPEG-I Stream Splitter
Filter Microsoft MPEG-4 Video Decompressor
Filter Multi-file Parser
Filter NSC file Parser
Filter Overlay Mixer2
Filter QT Decompressor
Filter QuickTime Movie Parser
Filter SAMI (CC) Parser
Filter VBI Surface Allocator
Filter VGA 16 Color Ditherer
Filter Video Renderer
Filter WM ASF Reader
Filter WM ASF Writer
Filter WST Decoder
Filter Wave Parser
Filter Windows Media Audio Decoder
Filter Windows Media Multiplexer
Filter Windows Media Update Filter
Filter Windows Media source filter
Filter XML Playlist
MEMORY INFO
Total Physical Memory 512 MB
Free Physical Memory 384.19 MB
Total Pagefile Memory 1.22 GB
Free Pagefile Memory 1.12 GB
MEMORY ARRAYS
Max Module Capacity 128 MB
Location <unknown>
Use <unknown>
Supported Error D&C Single-bit ECC
Supported Speeds 70ns, 60ns
Supported Types Standard, Parity, ECC, Fast-paged, EDO, SIMM
Supported Voltages 3.3V
MEMORY SLOTS
Installed & Enabled Size 256 MB
Form Factor <unknown>
Frequency 0 Hz
Slot ROW-0
Manufacturer
Type <unknown>
Type Details DIMM, SDRAM
Enabled Size 256 MB
Total Bit Width 0
Data Bit Width 0
Frequency 0 Hz
Slot ROW-1
Manufacturer
Type <unknown>
Enabled Size 256 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 0 bytes
Frequency 0 Hz
Slot ROW-2
Manufacturer
Type <unknown>
Type Details <unknown>
Total Bit Width 0
Data Bit Width 0
Frequency 0 Hz
Slot ROW-3
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer MSI
Model MS-6585
Version 1.0
BIOS Vendor American Megatrends Inc.
BIOS Version Version 07.00T
BIOS Release Date 07/03/02
BIOS Properties Plug and Play, Flash, AGP
CARD SLOTS
Number 1
Designation PCI1
Type PCI
Characteristics 3.3V, Shared, PME Signal
Data Bus Width 32
Details Available, Long
Device Class <unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID 0x0000
Device ID 0x0000
Device Sub-System ID 0x00000000
Device Revision 0x00
IRQ 0
Number 2
Designation PCI2
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 3
Designation PCI3
Type PCI
Data Bus Width 32
Details In Use, Long
Device Class Modem
Device Name Lucent Win Modem
Device Manufacturer Lucent
Device Driver Date
Device Vendor ID 0x11c1
Device ID 0x044a
Device Sub-System ID 0x044011c1
Device Revision 0x01
IRQ 19
Number 4
Designation PCI4
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 5
Designation PCI5
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 6
Designation ISA1
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 7
Designation ISA2
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
SYSTEM DEVICES
Description SiS Accelerated Graphics Port
Manufacturer Silicon Integrated Systems
Vendor ID 0x1039
Device ID 0x0001
Subsystem ID 0x00000000
Revision 0x00
Description SIS PCI to ISA bridge
Vendor ID 0x1039
Device ID 0x0008
Revision 0x04
Description PCI standard host CPU bridge
Manufacturer (Standard system devices)
Vendor ID 0x1039
Device ID 0x0648
Revision 0x02
Revision 3.0
Rate 4x, 8x (2x enabled)
Aperture Size 220 MB
Sideband Addressing supported (enabled)
Fast Write supported (enabled)
MONITOR INFO
MONITORS
Name MT-8617E
Manufacturer Iiyama
Max Width 0
Max Height 0
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System Microsoft Windows 2000
Version 5.0.2195
Service Pack Service Pack 2
Locale IS
Desktop Width 1024
Desktop Height 768
Desktop BPP 32
HARD DISK INFO
HARD DISKS
Name IC35L120AVV207-0
Manufacturer (Standard disk drives)
Capacity 115.04 GB
Model IC35L120AVV207-0
Interface Type IDE
Name MAXTOR 6L020J1
Capacity 19.14 GB
Model MAXTOR 6L020J1
Interface Type IDE
gumol: tha gurus don't sleep :)
gæti verið að þú hafir verið með un-installable version af Dx9 inni?
Ég veit að sum forrit(þ.m.t. 3dmarks) fatta ekki að Dx9 inniheldur alla dx8 instructions o.þ.a.l. biðja þig um að setja upp dx8. Síðan held ég að það hafi verið einhver útgáfa af dx9 sem að ekki væri hægt að downgrade'a.
2 ólíkleg scenario en kannski að það eigi við í þínu tilfelli?
Hvaða version af dx segir dxdiag að þú sért með?
-----(update)----
draslaðist til þess að lesa yfir loggin..... :)
þar segir að þú sést með Direct X 8.0 Install, gæti verið að þú hafir verið að dowloada vitlausri skrá?
Þessu áttu að download:
http://static.hugi.is/essentials/window ... 1NTeng.exe
-----(update)----
- Nörd
- Póstar: 145
- Nörd
- Póstar: 145
- Nörd
- Póstar: 145
