GPU artefacts/crashing
Re: GPU artefacts/crashing
did you try driver upgrade/downgrade?
Asus Maximus Xiii hero (WiFi)- Intel i5 11900K - Corsair Vengeance RGB PRO 4x8GB 3600MHz CL18 - Asus Strix 2080 - Samsung 1TB 980 PRO - samsung 500gb 970 evo plus - WD 12TB - Corsair RM750x - Corsair H150i pro - Corsair 678C Corsair virtuoso - Asus 27" - Corsair k95 platinum - Corsair Harpoon RGB - Lenovo G27Q-20 165hz 1440p
All of it. Clean install, DDU, BIOS flashing, underclocking, flashing BIOS from different manufacturers. Same results every time. Very likely to be degraded GDDR6 memory, since there have been a lot of similar cases for the RTX cards. I have run out of options that I can personally perform.nonesenze skrifaði:did you try driver upgrade/downgrade?
did you try it in a different computer?
That is the first thing you do when you test a component.nonesenze skrifaði:did you try it in a different computer?
Will Zotac not RMA even if you pay for shipping?
They dont answer to that question.Bourne skrifaði:Will Zotac not RMA even if you pay for shipping?
