Compatibility and Installation
Spire SkyMax is compatible with quite many graphics accelerators (check out the table in the next chapter of this review), but the latest products are missing from that list. Despite that, I can’t claim that the cooler will definitely be incompatible with Radeon HD 79xx, HD 78xx or GeForce GTX 6xx graphics cards. In order to make it easier to determine the compatibility of the new Spire SkyMax cooler with your particular graphics card, we will provide the distances between the retention holes: 59x59 mm, 54x54 mm and 65x54 mm. Besides, it is important to mention that the cooler base (with all aluminum inserts) is 70x68 mm. If your graphics card fits into the above listed measurement patterns, then the new Spire SkyMax cooler will most likely fit onto its without any problems.
