Til sölu ýmislegt til að vatnskæla, mest EKWB dót
Fletch
Póstar: 1225
Staðsetning: MHz=MHz+1
Póstur af Fletch »
EK-Quantum Kinetic TBE 200 D5 PWM D-RGB - Plexi
https://www.ekwb.com/shop/ek-quantum-ki ... i?___SID=U
Flott RGB Res&Pump combo, fylgir með bracket EK-UNI Pump Bracket (120mm FAN)
Screenshot 2021-09-01 205445.png (290.48 KiB) Skoðað 346 sinnum
Verðhugmynd: 15.000 kr
*SELD* CPU block *SELD*
EK-Quantum Velocity - AMD Copper + Plexi
Screenshot 2021-09-01 205941.png (146.23 KiB) Skoðað 346 sinnum
https://www.ekwb.com/shop/ek-quantum-ve ... i?___SID=U
Verðhugmynd: 7.000 kr *SELD*
Radiators
XSPC RX360 Triple 120mm Radiator
Dimensions: 130 x 56 x 398.5mm (WxDxH)
Verðhugmynd: 4.000
EK Ultimate Performance CoolStream 360 XTX Series Liquid Cooling Radiator
https://www.ekwb.com/shop/ek-coolstream-rad-xtx-360
Dimensions (LxWxH): 400x130x64mm
Weight: Approx. 1496g
Verðhugmynd: 6.000
Filling Bottle (1000mL)
Screenshot 2021-09-01 210300.png (26.03 KiB) Skoðað 346 sinnum
Verðhugmynd: 500
EK-AF Angled 90° 2F G1/4 Nickel
2 stk
Verðhugmynd: 1.000
EK-AF Ball Valve (10mm) G1/4 - Black Nickel
Valve (nota t.d. á drain line)
Screenshot 2021-09-01 204946.png (115.11 KiB) Skoðað 346 sinnum
https://www.ekwb.com/shop/ek-af-ball-va ... l?___SID=U
Verðhugmynd: 1.000
Einhver slatti af compression fittings 10/13mm ID/OD
Verðhugmynd: 500kr stykkið
EK-Quantum Flow Indicator D-RGB – Black - ónotað
https://www.ekwb.com/shop/ek-quantum-fl ... -rgb-black
Screenshot 2021-09-01 210704.png (64.77 KiB) Skoðað 346 sinnum
Verðhugmynd: 3.000
Aqua Computer Temperature sensor internal/external thread G1/4
Screenshot 2021-09-01 211106.png (129.12 KiB) Skoðað 346 sinnum
Verðhugmynd: 1.000
Velkomið að gera tilboð, í staka hluti eða allan pakkan
Áhugasamir hafi samband!
Last bumped by Fletch on Þri 07. Sep 2021 07:31.
