2080 Ti DUKE 11GB OC [SELT]
Læst
krazycs
Póstar: 15
Skráði sig: Mið 18. Des 2019 21:15
Póstur af krazycs »
Ég er að selja 4-5 mánaða RTX 2080 ti
var keypt á 220þ í tölvulistanum en það er ekki lengur í sölu hjá þeim :/
[Aldrei overclockað af mér]
Endilega senda mér tilboð
Hér eru basic uppl um kortið:
Core/Memory
Boost Clock / Memory Speed
1665 MHz / 14 Gbps
11G GDDR6
DisplayPort x 3 / HDMI x 1 / USB Type-C x 1
Triple-Fan Thermal Design
Using three of the award-winning TORX Fans 2.0 with Double Ball Bearings.
Using groundbreaking aerodynamic techniques, the heatsink is optimized for efficient heat dissipation.
TORX FAN 2.0: Supremely silent
Dispersion fan blade: Steeper curved blade accelerating the airflow.
Traditional fan blade: Provides steady airflow to massive heat sink below.
Double ball bearing: Strong and lasting core for years of smooth gaming.
RGB Mystic Light
Customize colors and LED effects with exclusive MSI software and synchronize the look & feel with other components.
Læst
